  3. SKILL to Identify a LABEL over an Instance
  • Replies 7
  • Views 21706
skillUserD
skillUserD over 6 years ago
I am in a need of a skill program to find all instances of a specific cell (Including Mosaics), throughout the hierarchy. The program should print the instance's name, xy coordinates at the top level, and extract a label name that is dropped on top of it. In case there is no label on top of the found instance, the program should print "No Label Found" in the report text file. This program aims to map PADs cells within top level.
I am using the below Cadence's solution to find instances and it works well. The missing feature is to identify LABELs that are on top of the found instances.
I tried to use dbGetOverlap() function, within the below code, in few setups but it seems to fail to identify the existence of labels on top of the found instances.
For example:
overlapLabel=dbGetTrueOverlaps(cv cadr(instBox) list("M1" "text"))
I am interested to add to the Cadence's solution below some code in order to identify labels on top of the found instances.
Any tip would be greatly appreciated.
Danny
procedure(HilightCellByArea(lib cell level)
let((cv instList rect instBox)
;; Deleting old highlights.To prevent uncomment the below line
when(boundp('hset) hset->enable=nil)
cv=geGetWindowCellView()
rect=enterBox(
         ?prompts list("Enter the first corner of your box."
                        "Enter the last corner of your box.")
     instList=dbGetOverlaps(cv rect nil level nil)
;; It uses hilite layer packet. You can change it to y0-y9 layer or any other hilite lpp
     ;;hset = geCreateHilightSet(cv list("y0" "drawing") nil)
     ;;hset = geCreateHilightSet(cv list("hilite" "drawing1") nil)
     hset = geCreateHilightSet(cv list("hilite" "drawing") nil)
        hset->enable = t
  foreach(instId instList
     if(listp(instId)
        then
        instBox=CCSTransformBBox(instId)
        instId=car(instBox)
        when(instId~>libName==lib && instId~>cellName==cell
                geAddHilightRectangle(hset cadr(instBox))
                fprintf(myFileId, "Highlighted the %L instance %L of hierarchy at:%L \n"
                        cell buildString(append1(caddr(instBox)~>name instId~>name) "/") cadr(instBox)
                     foundFlag=t)
        else
                geAddHilightFig(hset instId)
                fprintf(myFileId, "Highlighted the %L instance %L of top cell at:%L \n"
                         cell instId~>name instId~>bBox)
                         foundFlag=t
                );if listp
        ) ;foreach
t
) ;let
) ;procedure
procedure(CCSTransformBBox(inst)
let((flatList y location)
while(listp(inst)
        y = car(inst)
        flatList = append(flatList list(y))
        inst = cadr(inst) ; next inst
       );while
location=dbTransformBBox(inst~>bBox dbGetHierPathTransform(list(flatList inst)))
list(inst location flatList)
);let
);procedure
    It works OK for me - note that you have to use a different approach in different branches of the code, and maybe because your close parentheses were a bit screwy (I fixed those too) - I suspect you may have inserted the code in the wrong place. Shows the benefit of clean and consistent indentation...
    Note I didn't spend time formatting the output - I'll leave that to you (BTW, the layer was "Metal1" "label" in my case, so you'll need to fix that for your technology).
    ;; ANDREW passed in the file id as an argument (defaults to appearing in the CIW)
    ;; rather than having another global variable
    procedure(HilightCellByArea(lib cell level @optional (myFileId poport))
      let((cv instList rect instBox overlapLabel foundFlag)
        ;; ANDREW: using a global variable such as hset is a really bad idea as it's easy
        ;; to clash with somebody else's code. Note that this doesn't really delete the old
        ;; highlights either - it just  makes them invisible. I'd probably store the object as
        ;; a property on the window instead rather than making it global - if you are going
        ;; to make it global, use a prefix for the variable to make it unique
        rect=enterBox(
        hset->enable = t
          if(listp(instId) then
            instId=car(instBox)
              foundFlag=t
              overlapLabel=dbGetTrueOverlaps(cv cadr(instBox) list("Metal1" "label"))
              fprintf(myFileId "LABEL FOUND: %L\n" overlapLabel~>theLabel)
          else
              foundFlag=t
              overlapLabel=dbGetTrueOverlaps(cv instId~>bBox list("Metal1" "label"))
          );if listp
        ) ;foreach
        t
      ) ;let
    ) ;procedure
        while(listp(inst)
          y = car(inst)
        );while
      );let
    );procedure
  • skillUserD
    skillUserD over 6 years ago in reply to Andrew Beckett
    Andrew, question please, what if I would like to identify a LABEL of any layout/purpose types on top of the instance?
    For example: The label can be of:  "M1" "drawing" or "text" "drawing" or any other type.
    That's not so easy, because whilst dbGetOverlaps allows you to specify t as the layer/purpose arg, it's going to then find every shape of every type down to the specified level of hierarchy in that region - which could be a LOT of shapes. You can then filter them to find those with objType="label" but I don't think there's a direct way of finding just a subset of the object types directly.
    If the label is always at the same level of the instance, potentially you could do a hierarchy traversal and find the instances at level 0 only and the shapes at level 0 only which might make it easier to find as it would have fewer shapes to deal with (only shapes that overlap with the instance at that level). However, then you'll have to do the hierarchy traversal too and sort out all the transformations to the top level (not that hard, but more work). It's probably going to be a simpler and quicker change to limit yourself to a few lpps and loop over them to find any of them.
  • skillUserD
    Thanks for the support and tips Andrew.
    Danny
  • skillUserD
    Andrew, it seems like the code doesn't go down the hierarchy. It identifies the labels on the same level but if I put it few cells below, it doesn't find it.
    I tried using some transformtions but it seems not working....
    Andrew Beckett over 6 years ago in reply to skillUserD
    Sorry, I didn't exhaustively test the code because I didn't entirely know what you wanted - and I was leaving it to you to correct for your precise needs. Because you're just using the output of dbGetOverlaps from the top level, you'd want to pass level as the dbGetTrueOverlaps calls used to find the labels. At the moment, no fourth argument is passed, and so it defaults to top level labels only. You'd then need to process the resulting lists to find the actual label object at the end - simplest is to call something like this on each result of the dbGetTrueOverlaps - since you're only trying to find the actual label text:
    Using abGetHierPathShape from this code will help. You could then do (and I didn't test this):
    foreach(overlapLabel dbGetTrueOverlaps(cv cadr(instBox) list("Metal1" "label") level)
    actualLabel=abGetHierPathShape(overlapLabel)
    when(actualLabel~>objType=="label"
    fprintf(myFileId "LABEL FOUND: %L\n" actualLabel~>theLabel)
  • skillUserD
    Thanks Andrew. It works great.
    Danny
