  3. pcell
  • Replies 8
  • Views 17680
pcell
raegaan
raegaan over 6 years ago
writing skill code for the diode(pcell) .How to get(calculate) the area of diode from techfile??
Thanks and regards
Raegan
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to raegaan +1
    you may find SKILL code for some pcells here, <virtuoso_install>/tools/dfII/samples/ROD/rodPcells/components/. A diode pcell can be coded similarly to eb junction of a BJT. Guangjun
    Which tech file are you talking about? I don't know anything about a Virtuoso tech file that contains the area of a diode...
  • raegaan
    raegaan over 6 years ago in reply to Andrew Beckett
    then how to determine the min dimensions of diode.
    raegaan
  • raegaan
    raegaan over 6 years ago in reply to raegaan
    or can you suggest some reference where I can get this
    raegaan
    Andrew Beckett over 6 years ago in reply to raegaan
    This will rather depend on the layout structure of the diode, whether the tech rules for those layers are in the tech file, and whether the minimum device size corresponds to the simple layer rule info (the minimum might be larger, who knows?)
    To be honest, this is far too open ended to be able to answer.
  • raegaan
    can you suggest where can I find  pcell code of any diode??
    Thanks and Regards
    Raegaan
    I did a quick search and couldn't find open source code for this, sorry.
  • raegaan
    ok thanks Andrew
    Regards
    raegaan
  • Guangjun Cao
    Guangjun
