  3. using wildcard matching in net name equating
  • Views 17605
MalcolmWhiteLayout
MalcolmWhiteLayout over 6 years ago
I'm doing a small widget where I have something like:
wirelist=selectedSet()
foreach(wire wirelist if(wire~>net~>name=="net*"
except instead of the net* - skill doesn't take the wildcard symbol (that I'm aware of)  I know I have to use a matching function
of some sort - how do I combine the first 3 characters "net" with the numbers which are assigned to internal net names
using some sort of regExp or regMatch function ?
using cadence 6.1.8
Thanks.
    You could use pcreMatchp(), so:
    foreach(wire wirelist if(pcreMatchp("^net\\d+$" wire~>net~>name)
