  3. dbConcatTransform calculation error
  • Views 16623
NickA
NickA over 6 years ago
I'm tryinng to compute teh location of a pin which is several levels down in the hierarchy...
Top layout
    -> Analog instantiated in top with rotation R0 at (0,0)
           -> General instantiated in Analog with R0 at(819.22,136.62)
                  -> Osc instantiated in General with MX rotation at (1811.96,2255.96).
Inside Osc there is a pin at local coords (101.485,1.625). In the top level this appears at (2733.665,2390.955), ie (819.22+1811.96+101.485 , 136.62+2255.96-1.625). However, when I combine the General and Osc coordinates with dbConcatTrasform, it returns the Osc location as 2631.18,2119.34. The x-coord is correct, but the Y is not. It appears to be getting confused by the MX rotation.
I'm using Result = dbConcaatTransform(Arg1 Arg2), with the below values
Arg1: ((819.22 136.62) "R0" 1.0)
Arg2: ((1811.96 2255.96) "MX" 1.0)
Result: ((2631.18 2119.34) "MX" 1.0)
Any idea what I'm doing wrong?
    Andrew Beckett over 6 years ago +1
    You have the arguments to the dbConcatTransform the wrong way around. You need to start bottom-up (left to right): Result = dbConcaatTransform(Arg2 Arg1) ((2631.18 2392.58) "MX" 1.0) Then if you…
    Then if you do:
    dbTransformPoint(pinLoc Result)
    it outputs:
    (2732.665 2390.955)
  • NickA
    NickA over 6 years ago in reply to Andrew Beckett
    Yes, that worked. Thanks very much!
