  3. How to invert a transform?
  • Subscribers 152
  • Views 18821
DaveZhang
DaveZhang over 6 years ago
Hi all,
I have a bbox in top level and a transform for a bottom cell, how to invert the bbox to the bottom cell?
Any suggestion will be thankful!
Dave.
  • NickA
    NickA over 6 years ago
    Does this help?
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/14265/transform-shapes
    Possibly this alsol...
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/45246/dbconcattransform-calculation-error
  • DaveZhang
    DaveZhang over 6 years ago in reply to NickA
    Hi Nick,
    I have searched those content,and it's unable to meet my requirements.
    both of them are discussed how to transform a bBox from bottom to top level,  but my goal is transform bBox from top to bottom level.
  • NickA
    NickA over 6 years ago in reply to DaveZhang
    Can you not do what I did incorrectly when I used it first, and use the dbConCatTransform function with the arguments swapped?
    Andrew Beckett over 6 years ago in reply to NickA
    Alternatively, you could use this implementation (you might want to contact customer support to request a duplicate of CCR 688096 for a built-in inverse; I discovered yesterday that there had been several independent requests for this, so I grouped them together to make it clearer that there was a bit of demand for it). The code below is based on something written by a former member of my team who came up with a workaround.
    /* abInvertTransform.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 11, 2020
    Modified
    By
    Implementation of a function to invert a transform, given that
    there is no dbInvertTransform available in SKILL (exists at the C
    level, but not in SKILL) (CCR 688096 and duplicates are requesting
    this)
    SCCS Info: @(#) abInvertTransform.il 06/11/20.05:34:10 1.1
    *                  (abInvertTransform transform "l")                  *
    * The dbInvertTransform function is not exposed to SKILL, so this is  *
    * a SKILL implementation which does the same. The idea is that if you *
    *    do dbConcatTransform(tr abInvertTransform(tr)) it will return    *
    *                         ((0.0 0.0) "R0" 1)                          *
    (defun abInvertTransform (transform "l")
      (let ((orient (cadr transform))
            (mag (cond
                   ((zerop (caddr transform))
                    (error "cannot invert transform with mag=0: %L" transform))
                   ((null (caddr transform))
                    1)
                   ((caddr transform)))))
        (dbConcatTransform
          (list
            (list (minus (xCoord (car transform)))
                  (minus (yCoord (car transform))))
            "R0"
            1.0)
          (list
            '(0.0 0.0)
            (case orient
              ("R90" "R270")
              ("R270" "R90")
              (t orient))
            (quotient 1.0 mag)))))
  • DaveZhang
    DaveZhang over 6 years ago in reply to Andrew Beckett
    Thanks Andrew,
    The code is working well.
