  3. How to determine if there is a given layer in a specific...
  • Views 18647
How to determine if there is a given layer in a specific area in layout
RodrigoPeres
RodrigoPeres over 6 years ago
Hi all,
I would like to check if there is a given layer in a specific area in my layout. For example, check if there is any Metal 1 in the square area limited by (0;0) and (5;5).
I could not find yet a way to do that through SKILL, would you have any suggestions?
Thanks in advance.
  • mbracht
    mbracht over 6 years ago +1
    Hi Rodrigo, The leSearchHierarchy() function does that...here's an example: leSearchHierarchy( cv list( 0:0 5:5 ) 0 "any shape" list( list( "layer" "==" list( "poly1" "drawing" ) ))) Max
  • mbracht
    Hi Rodrigo,
    Max
  • RodrigoPeres
    RodrigoPeres over 6 years ago in reply to mbracht
    Cool, it worked perfectly. Thanks a lot Max!
    Andrew Beckett over 6 years ago in reply to RodrigoPeres
    Alternatively you could use dbGetOverlaps() - this is a lower level function to do this - and you can then control the hierarchy depth to search for. If it was me, I'd use dbGetOverlaps or dbShapeQuery.
  • RodrigoPeres
    RodrigoPeres over 6 years ago in reply to Andrew Beckett
    Interesting. Thank you for the tip Andrew.
