  3. Cadence Auto Route Issue
  • Views 17446
Amar Kumar
Amar Kumar over 6 years ago
I am trying to use cadence auto-route feature in a simple layout.
I generated the pins and devices using "GenFromSource", then when I go to "Route -> Automatic Routing -> All Nets",  It runs for 2 sec and ends up with below  error.
* Begin Min-Spanning-Tree Routing Flow for Normal Nets *
REPORTING_STATS | Elapsed Time: 0.0 Secs | Mem: "Current: 2815.00" Mb | Cmd: initialize_partition -set sel:4e73b690
[::iaAutoRoute::INFO] Number of inaccessible terms reported by routability checker: 3
[::iaAutoRoute::INFO] Number of nets to be excluded for routing: 3
[::iaAutoRoute::INFO] Number of terms to be excluded for routing: 0
*WARNING* Command wrongway_pin_escape requires application feature Router only that cannot be licensed.
*WARNING* TCL error: ERROR - no further information available.
nil
Can anyone help to understand the issue ? I am doing this in Layout-XL.
Thanks In Advance,
Amar
    Hi Amar,
    This sounds as if you don't have sufficient GXL licenses. See License error when trying to invoke the VSR automatic routing and use 'Generate Routing from Topology' in Modgen Editing
    If it's not that, I suggest you contact customer support.
  • Amar Kumar
    Amar Kumar over 6 years ago in reply to Andrew Beckett
    Hi Andew,
    Thanks, It helped. I feels I don't have enough XL licenses to run the Route command.
    Regard,
    Amar
    Andrew Beckett over 6 years ago in reply to Amar Kumar
    Hi Amar,
    You need GXL licenses to run the router (for anything beyond a single net, which you can route with XL). You can use XL for the layout cockpit, but the router will need GXL tokens.
  • Amar Kumar
    Thanks for the information again.
    I was trying to use router(All Net) without GXL lic. So it ends up with the error.
    Amar
