  3. Techfile - minspacing 'sameNet parameter with wells
  • Views 2168
meredith
meredith over 5 years ago
Is it possible to setup the minSpacing constraint parameter 'sameNet to work with wells?  For example, a process may set a rule for minimum space between two N+ wells connected to the same potential as 1µm and the minimum spacing between two N+ wells connected to different potentials to 2µm.
I've tried the using the following lines in a techfile without any luck: minSpacing "layerName" 'sameNet 1
The minSpacing for layerName uses 1µm for shapes on layerName with and without the same Route Net Name.
  • meredith
    Using Cadence version ICADVM20.1
    Andrew Beckett over 5 years ago in reply to meredith
    I just did some quick experiments and I could get it to work (using VLS XL, and checking with DRD) if I have:
     ( minSameNetSpacing "Nwell" 0.3 'ref "NW.SP.1" 'description "Minimum Nwell Spacing (same potential)" )
    but it doesn't seem to work with:
    ( minSpacing "Nwell" 0.2 'sameNet 'ref "NW.SP.3" 'description "Minimum Nwell Space (same potential)" )
    I intentionally used a different number to help with testing. I suggest you contact customer support, because I don't know which application you're hoping to enforce this with, and it may just need some more testing, and I don't really have the bandwidth to do that and follow up with R&D this week, I'm afraid.
  • meredith
    meredith over 5 years ago in reply to Andrew Beckett
    Hi Andrew
    Thank you for taking the time to test this out and the advice.
    -Meredith
