  3. How to enable TMI menu in ADE
  • Subscribers 150
  • Views 15367
FormerMember
FormerMember over 5 years ago
Hi, guys
I'm using IC618 and try to run some aging simulation with TMI. But there is no TMI option automatic enabled in reliability menu. So I did the following command in my CIW window :
envSetVal("afs.relxOpts" "displayTMIGui" 'boolean t)
and then use senGetVal to get a return of t. so I guess it has setup.
But, when I back to check the reliability menu in ADE, the TMI menu is still not appear. Does anyone can give an instruction to solve it?
Fmeng
    Fmeng,
    As far as I know, reliability analysis via the reliability analysis setup in ADE L/XL/Explorer/Assembler is only supported for Cadence simulators - you are setting an environment variable here for a non-Cadence (Mentor/Siemens) simulator.
  • FormerMember
    FormerMember over 5 years ago in reply to Andrew Beckett
    Hi, Andrew,
    Thanks for your reply. I change the command to envSetVal("spectre.relxOpts" "displayTMIGui" 'boolean t) and it works.
    Fmeng
