  3. calculator numconv function
  • Replies 50
  • Views 39009
abdurrahman0234
abdurrahman0234 over 5 years ago
When ı plot to calculator, I get error as below. I want to convert binary signal to decimal.Please can help me.
ERROR (VIVA-3002):expression evaluation failed: val is not legal.
ERROR (VIVA-3002):expression evaluation failed: numConv(VT("/out<0:2>") "dec" t)
  • abdurrahman0234
    abdurrahman0234 over 5 years ago in reply to Andrew Beckett
    I understand sir. But I get no digital signal as in the above pic when convert analog to digital. Why please
  • abdurrahman0234
    abdurrahman0234 over 5 years ago in reply to abdurrahman0234
    SORRY. I achieved
  • abdurrahman0234
    while converted digital to analog, high and low voltages range is; -4*840m for low and 3*840m for the decimals between  -4 and 3?
  • abdurrahman0234
    (vhi+vlo)/2 this formula is constant?
    Andrew Beckett over 5 years ago in reply to abdurrahman0234
    That's rather up to you. It depends on what you want the range of the final "analog" representation of the bus to be. It could be -4 and 3. I don't really see why you'd need to multiply it by 840mV.
  • abdurrahman0234
    because first high bit voltage level 840m
    I assume you're referring to the X: (vhi+vlo)/2. That is indicating what voltage would be used if there are any "unknowns" in the digital waveform. There won't be if you use the "Center" mode in the analog to digital (you'll only get X if you have used the High/Low setting on analog to Digital, and the signal stays between the low and the high for longer than a certain time).
    As I said, it's entirely up to you. I can't really see why you would need to scale it, but presumably you know what you're trying to do with the result!
    Anyway, hopefully all is clear now.
  • abdurrahman0234
    I wanted to say, for example, -4 deciöal number, voltage level 840*-4 or x*-4. x depends on the before voltage level
  • abdurrahman0234
    thanks very much Sir.  I get below error while simulate psd.How can I solve this?
    The signal x-axis vector values are not uniformely distributed. Data was interpolalated, which would create numerical noise and differences. To remove these errors, use uniform raw data points.
