  3. calculator numconv function
  • Replies 50
  • Views 39034
abdurrahman0234
abdurrahman0234 over 5 years ago
When ı plot to calculator, I get error as below. I want to convert binary signal to decimal.Please can help me.
ERROR (VIVA-3002):expression evaluation failed: val is not legal.
ERROR (VIVA-3002):expression evaluation failed: numConv(VT("/out<0:2>") "dec" t)
    Andrew Beckett over 5 years ago in reply to abdurrahman0234
    Please don't ask this new question on the end of the old thread (the forum guidelines ask you not to do this).
    So please post a new question, with sufficient information that others can help you (I don't know where to start from your question above, since there's absolutely not enough information to understand what you're doing or what might be wrong, if anything). Perhaps somebody else will be able to figure out what you meant.
  • abdurrahman0234
    abdurrahman0234 over 5 years ago in reply to Andrew Beckett
    Sır, dıgıtal bıts are converted to analog bıts, wrongly. For example, digital bit '4' is converted to 226mv and  bit '-1' is converted to 336mv. I dont understand
  • abdurrahman0234
    abdurrahman0234 over 5 years ago in reply to abdurrahman0234
  • abdurrahman0234
    Why negative decimals dont take a negative voltage
    I don't understand either, mainly because you've posted on the end of an old thread (you had this working before, so I presume it's something different) and you've not provided any supporting information - such as a graph of the results, what you entered on the form, and so on. I can't read your mind!
  • abdurrahman0234
    when ı converted  digital bits to analog bits, ıt takes decimals wrongly for the voltage output. For example, '-1' digital bit should be 840mv or else '-2' decimal should be at the minumum level but graph show not coorect
  • abdurrahman0234
    analog bıts shows not correct for the digital bits.Hı:3360m li:-840m X=(Xİ + Lİ)/2
    OK - when I posted before I'd not seen your picture as you posted three posts rather than combining into one.
    It seems that when converting the digital bus back into a single analog waveform, the conversion does not take into account whether you'd marked your bus as being displayed with the radix signed or unsigned. It simply uses the value of the bus as a binary sequence - it seems to always be treated as unsigned. It would seem to be a reasonable enhancement request to allow the conversion to analog to treat the input as a signed bus - so you should contact customer support to request this enhancement.
    Goodness me, whilst typing this you've posted 3 more single line responses. You're doing your best to really annoy me so this will be my last answer.
  • abdurrahman0234
    Ok, Sir. I have to look psd of the analog bits. There are any way of  digital bus converting to analog? I think that ıt will not be correct sımulation with wrong analog bits
    Now I'm going to go against what I said earlier. You should still contact customer support for this, but it's actually possible to convert the value the way you want. In my case I have an 8 bit unsigned bus, so I converted this to analog with a minimum of 0, and maximum of 255. I then sent this to the calculator:
    awvDigital2Analog(awvCreateBus("thebus" list(awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<7>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<6>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<5>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<4>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<3>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<2>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<1>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<0>" ) nil nil 0.4 nil "centre") ) "Signed Decimal") 255 0 "(vhi+vlo)/2" ?mode "busvalue" ?outWaveType "zeroT" ?risetime 0 ?falltime 0)
    I added 128 (i.e. half the range of an 8 bit value), and then surrounded the expression with abApplyToTwoWaves('modf expression 256.0) as found in this post. So I got this:
    abApplyToTwoWaves('modf awvDigital2Analog(awvCreateBus("thebus" list(awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<7>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<6>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<5>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<4>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<3>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<2>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<1>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<0>" ) nil nil 0.4 nil "centre") ) "Signed Decimal") 255 0 "(vhi+vlo)/2" ?mode "busvalue" ?outWaveType "zeroT" ?risetime 0 ?falltime 0)+128 256.0)
    I finally subtracted 128 again, and got this:
    abApplyToTwoWaves('modf awvDigital2Analog(awvCreateBus("thebus" list(awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<7>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<6>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<5>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<4>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<3>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<2>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<1>" ) nil nil 0.4 nil "centre") awvAnalog2Digital(leafValue( VT("/data<7:0>") "bit" "/data<0>" ) nil nil 0.4 nil "centre") ) "Signed Decimal") 255 0 "(vhi+vlo)/2" ?mode "busvalue" ?outWaveType "zeroT" ?risetime 0 ?falltime 0)+128 256.0)-128
    This gives me:
    Note that my vertical markers are showing the bus value (the bus has a signed decimal radix) - and you can see the voltages match. Of course, if your bus widths are different you'll need to change the 128 and 256 in the above expression (note the last argument of abApplyToTwoWaves needs to be a float, so must have .0 at the end).
    Of course, this would be much simpler if there was a built-in way to convert the digital to analog treating it as a signed number in the first place (but that needs an enhancement). You could also write a Verilog-A DAC model which does the same thing.
