  3. how to disable combobox using another combobox skill vi...
  • Views 11884
how to disable combobox using another combobox skill virtuoso
saurabh96
saurabh96 over 5 years ago
Hey,
I have created 3 combo boxes...combo box 1 contains 4 elements 1,,2,3,4....Combo box 2 contains a,b,c.....Combo box 3 contains x,z ..now I want when I select element 1,3 from combo box 1, only options a,c will visible in combo box 2 and combo box 3 will get disabled and vice-versa when I select option 2,4 from combo box1 only b option should be visible from combo box2 and x,z should be visible in combo box 3... So how can we make them interdependent using the skill?
Pls, guide!
    The guide is to use exactly the same approach as was suggested in my answer to your other question:  How to switch off and on the String fields option using radio button. Oh, hang on, you've edited the question and you're also asking to update the items in the combo box. Well, guess what, have some code to update ->items on the field in the callback function. If it was a cyclic field, it would be that you update the ->choices slot.
    Or perhaps your question is "can you just write my code for me?"
