  3. Exact ViVA proint to file
  • Replies 9
  • Views 15107
dragank
dragank over 5 years ago
Hi all,
I am trying to export ViVA graphs to file using:
saveGraphImage(?window win ?fileName outFileName ?exactCopy 't)
Before that I am doing:
awvPlotWaveform(win list(wavefrm) ?expr list(strcat(ss "(" getCornersAndValuesText(historyName cn) ")")) ?stripNumber list(i))
While running the code it is notable that ViVA renders waveforms in two steps, first is rough and second is much finer and corresponds to expected waveforms.
But saveGraphImage captures and saves initial (rough) shapes of waveforms.
Is there a way to wait for ViVA do it's job complete so saveGraphImage can capture expected images?
Thanks in advance.
    Version?
  • dragank
    dragank over 5 years ago in reply to Andrew Beckett
    Andrew Beckett over 5 years ago in reply to dragank
    This looks as if it's probably due to a known bug (CCR 2209855 for my reference) which was fixed in IC6.1.8 ISR15 (so IC6.1.8-64b.500.15). You'll need to update to a later hotfix of IC618 (ideally the latest). If you still see the problem then, please contact customer support. It was due to a performance optimisation that was done earlier in IC6.1.8 and unfortunately this was a regression caused by an improvement elsewhere.
  • dragank
    May this be related to axlPlotAcrossDesignPoints plots blank diagrams and later adds curves?
    When I plot in loop I get empty windows.
    No, I don't think it has anything to do with that. This is a specific issue with graph plotting and saving to images.
  • dragank
    So, I wait for update to be done also ?
    Wait for what? Have you tried with the newer version and shown that your issue with axlPlotAcrossDesignPoints still occurs? If so, you should report it to customer support as it won't get magically fixed unless we know about it (and have some means of reproducing it). The fix for the saveGraphImage has been out since November 2020.
  • dragank
    Ok. I must wait for update because I can not do it.
  • dragank
    Thank you. I have to wait for update from people that are doing it.
