  3. How to change net name of instance terminals
  • Subscribers 152
  • Views 14898
Suresh Layout
Suresh Layout over 5 years ago
I tried to change the net names of instance terminals . since It is working when i gave single net name for all terminals .
x=css()
new_net = dbMakeNet(geGetEditCellView() "net1")
x~>instTerms~>net = new_net
Result
db:0x8e10659b
(db:0x8e10659b db:0x8e10659b db:0x8e10659b db:0x8e10659b db:0x8e10659b
But It is is giving error when i gave multiple net names  in list
All_nets = list(new_net new_net new_net new_net new_net new_net new_net)
 x~>instTerms~>net = All_nets
Result
*Error* dbSetq: Invalid net - (db:0x8e10659b db:0x8e10659b db:0x8e10659b db:0x8e10659b db:0x8e10659b ... )
<<< Stack Trace >>>
setSGq((x~>instTerms) All_nets net)
So please correct me where i am wrong .
  • ebecheto
    ebecheto over 5 years ago
    maybe something like :
    foreach(mapcar net  x~>instTerms~>net
    net=newnet
    Andrew Beckett over 5 years ago in reply to ebecheto
    That approach won't help. It's not clear why you would be trying to assign as a list (if all the nets are the same), but if you have a list of instTerms, and a list of nets (All_nets) you'd do this:
    foreach((instTerm net) x~>instTerms All_nets
      instTerm~>net=net
    This is looping over two lists together - the list of instTerms and the list All_nets and then dealing with each assignment one by one.
  • samiirlore
    samiirlore over 5 years ago
    I am able to change the session name of the active terminal by selecting Terminal: Rename from the Command Palette (Ctrl+Shift+P), then changing the name to whatever I want. However, after restarting VSCode, when the terminal starts again, the name reverts back to the Tutuapp 9apps Showbox original name.
    Andrew Beckett over 5 years ago in reply to samiirlore
    I'm struggling to figure out why you are posting on a thread about changing terminal names in Virtuoso when it's clear you're talking about Visual Studio Code which has nothing to do with this. None of the forums here have the slightest relevance to Visual Studio Code...
