  3. how to delete value of field using radio button
  • Views 12079
saurabh96
saurabh96 over 5 years ago
Hello Everyone,
How can we delete pre-filled value from field using radio button.
Suppose..i have two string field a and b and two radio button c and d............and both string fields contain some pre-defined values.
I want that if i choose radio button d, value from field b will be deleted if any value is available there.....same if i choose button  c ,value from field a will be deleted.
How can we do that?
    Have a callback on the radio button set the form->field->value on the other fields to "" as appropriate (e.g. form->field->value="").
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Thanks Andrew
