  3. schematic symbol label lpp info
  • Views 14046
psill00
psill00 over 5 years ago
Are there any problems with changing the schematic symbol label lpp to another lpp than '("pin" "label")
I want to change the label lpp so I can have different label colors to correspond to different metals the route needs to be routed.
Changing the lpp is a quick identifier than going through a properties or constraints.
Paul
    Hi Paul,
    The layer-purpose pairs used by the labels is pretty unimportant. One thing to be aware of is that the View->Hide Instance Labels/View->Hide Terminal Labels only works on a few specific layer-purposes, but other than that the LPP shouldn't matter.
  • psill00
    psill00 over 5 years ago in reply to Andrew Beckett
    Thanks for the info
  • psill00
    psill00 over 5 years ago in reply to psill00
    I dont know if I should start a new thread, but is there schematic/symbol equivalent to these functions
    leSetAllLayerVisible
    leSetLayerVisible
    leIsLayerVisible
    Andrew Beckett over 5 years ago in reply to psill00
    No, there isn't. You could just write your own using the tech file functions techGetLPAttr/techSetLPAttr, or just set the visibility attribute on the LP object in the tech file. There's no layer palette in the schematic/symbol editor, so they wouldn't quite make sense.
    This post might give you some clues.
