  3. update the layout connectivity by shorting two terminals...
  • Views 13626
update the layout connectivity by shorting two terminals of Analog lib Resistor in layout
naresh9005
naresh9005 over 4 years ago
Hi
we have many analoglib resistors in our schematic, we will be filtering these resistors and short the two terminals while running LVS by using  (asura/pvs) commands, because these does not represent any physical device.
but problem with this resistor is, it is breaking the connectivity in layout,
Take an example of analoglib resistor "R",  two terminals are connected to "netA" and "netB"  respectively  in schematic, while doing layout i suppose to ignore resistor(R) and short netA and netB. is there any way to update the layout connectivity by this way.
we are able to filter out analoglib resistor connected nets by using below code,
procedure(FilterAnalogLibResNets()
cv = geGetEditCellView()
analoglibres = setof(resinst cv~>instances resinst~>libName == "analogLib" && resinst~>cellName == "res")
foreach(analoglibres1 analoglibres
neta = car(analoglibres1~>instTerms)~>net~>name
netb = cadr(analoglibres1~>instTerms)~>net~>name
printf("Two terminals of Analoglib resistor are connected to net %s and net %s these two should short in layout \n" neta,netb)
);foreach
is there any way to update the layout connectivity by shorting neta and netb?
Regards
Naresh
    Hi Naresh,
    The analogLib res component has been updated from IC618/ICADVM201 ISR14 onwards to be treated as a short by Virtuoso Layout Suite XL, but in versions prior to that you can Launch->Configure Physical Hierarchy and then go to the Cells tab, select the analogLib/res row, and set the Remove Device entry to (short(PLUS MINUS)) as follows:
    This will then ensure that the connectivity is made between the ends of the analogLib res devices.
  • naresh9005
    naresh9005 over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, Now it is working fine.
