  3. Re: prevent string choices of verilogA from splitting into...
  • Views 11963
Re: prevent string choices of verilogA from splitting into two lines
slim15
slim15 over 4 years ago
I created a verilogA block to generate different static output depending on a parameter call Mode that can have two values, "power down" and "calibration". This verilogA is instantiated on a schematic view and the chosen values is determined by a pull down menu by modifying the CDF of this block where Mode is set as a cyclic button and choices having the following entry: power down,calibration
The verilogA code is as follow:
// VerilogA for sandbox, simCell_DAC, veriloga
`include "constants.vams"
`include "disciplines.vams"
module simCell_DAC (VDD, VSS, DAC_D);
output [1:0] DAC_D;
inout VDD, VSS;
electrical [1:0] DAC_D;
electrical VDD, VSS;
integer VAL_DAC_D=0;
parameter string Mode = "power down";
genvar i;
analog begin
case (Mode)
"power down" : VAL_DAC_D = 1;
"calibration" : VAL_DAC_D = 3;
default: VAL_DAC_D = 2;
endcase
for (i=1; i>=0; i=i-1) begin
V(DAC_D[i],VSS) <+ (VAL_DAC_D>>i)&1 ? V(VDD) : V(VSS);
end
end
endmodule
On the occasion where the netlister splits the "power down" into two lines like below
  I0 (VDD_TOP VSS_TOP DOUT\<1>\ DOUT\<0\>) simCell_DAC Mode="power \
down"
the default option within the case-statement will be called instead of the "power down". Is there a way to either prevent the netlister from splitting the "power down" string into two lines or verilogA case statement to accept breakage?
    I don't see this behaviour unless I mess around with hnlMaxLineLength. So try setting this (best in the .simrc, but could also be in .cdsinit I think):
    hnlMaxLineLength=1024
    (you might also need to set hnlSoftLineLength=0 )
    Please contact customer support though - the netlister should behave properly here, especially if it affects the parameter passed into the Verilog-A module.
