  3. How to move custom_menu items to pre-existing menu item...
  • Views 10924
How to move custom_menu items to pre-existing menu items
saurabh96
saurabh96 over 4 years ago
Hi there,
I have created a custom menu i.e Main Menu..by below following script-
procedure(Menu_CIW_TOP()
ciwMenuInit()
menuItem_11=hiCreateMenuItem(?name 'item11 ?itemText "ITEM 11" ?callback "f11()")
submenu1 = hiCreatePulldownMenu( 'Menu_CIW1 "Menu1" list( menuItem_11 ) )
slider1=hiCreateSliderMenuItem(?name 'slider_CIW1 ?itemText "Menu1" ?subMenu submenu1)
menu_ciw_top = hiCreatePulldownMenu('Menu_CIW_TOP "Main Menu" list(slider1))
hiInsertBannerMenu( window(1) menu_ciw_top 9)
Menu_CIW_TOP()
Now i want to move "Main Menu" custom menu item to "Solido" menu item in CIW.
so that when the click solido option , "Main Menu" option appears in it as sub-menu and then i will able to select according to it.
How can i acheive it??
    This appears to be essentially the same question as your other post How to create and add submenu options in virtuoso window (if it's not, you're going to have to more clearly describe it - the other post was very unclear too).
