  3. Exit after a simulation is complete
  • Views 13501
Jonty
Jonty over 4 years ago
I am running simulation from a skill script using the following command, and I am using the command "virtuoso -nocdsinit -nographE -restore mySkill.il" to load the SKILL script.
maeRunSimulation(?session sn )
I want to exit from the virtuoso prompt after simulation is complete, but when I use "exit" after the above command, the script exits before the simulation is complete.
Is there a fail-safe way to exit virtuoso after completing the simulation?
Thank you!
    You can either pass ?waitUntilDone t to the maeRunSimulation function, or you can use the return value of maeRunSimulation as one of the list you pass to the maeWaitUntilDone function (the latter is useful if you've submitted several simulations and want to wait for them all, rather than waiting for them in turn).
  • Jonty
    Thank you for your response. A follow-up question related to my next step: I want to export a few waveforms that are the results of "expressions" into csv file for further processing (As I understand, these aren't part of the results database like the net-based waveforms).
    I am using awvSaveToCSV() but it doesn't provide information about the X and Y units. I also came across your script from the post below which works well. Has there been any update to that script ?
    skill func for exporting csv - Custom IC SKILL - Cadence Technology Forums - Cadence Community
    Thanks.
    Andrew Beckett over 4 years ago in reply to Jonty
    That's the latest version of that code.
  • Jonty
    Jonty over 4 years ago in reply to Andrew Beckett
    Thank you!
