  3. Convert 45 degree polygon to staircase
  • Views 11284
prasadtammana
prasadtammana over 4 years ago
I need a script to convert a 45 degree angle polygon to staircase as shown in the image below. I'm asking because I want to draw PTAP guardring along the edge of the polygon. If the shape is diagonal, the fluid guardring shapes are off the grid and creating drc errors. Could someone share the script if you have any already. Or please let me know the command or give me some hint, so I will try to write the script by myself.
Prasad
    See How to convert a non-orthogonal polygon shape to have staircase stepped edges (it's my code).
  • prasadtammana
    prasadtammana over 4 years ago in reply to Andrew Beckett
    Hi Andrew, Thank you so much for the code. It exactly does my job. Thank you.
