  3. how to convert a "waveform object" into an "array" or "list...
  • Views 5753
how to convert a "waveform object" into an "array" or "list" to iterate over each point?
SC6789
SC6789 over 4 years ago
The details below are specific to my design but the question is more broad, as in subject.
Using Cadence 6.1.8 I'm simulating noise of a clocked comparator. I'm running a 100-set of short transient simulations with noise (using transient sim options), while parameterizing a variable (x) that scales the size of some FETs in the circuit. My goal is to measure the final value of the transient sim (either High - close to vdd, or Low - close to gnd) for each transient curve in the 100-set. I am counting the  # of Highs in the 100-set, which is the figure of merit. Then I will list this number against each value of the swept parameter "x".
The brute-force approach I use (after simulations) is to loop over transient-noise "Iterations", as well as over the parameter "x" and use the data as I need. I access each end point of transient using:
leafValue( value( VT("/q1") 82e-12 ) "x" x "Iteration" iter )
The downside is that it's slow to access one final transient point at a time, => the loop takes several seconds per each "x" value. This is very slow, especially for many "x"s.
But I noticed that instead to access final pts for all 100 transients at once is quick (< 1s for all 100 transients):
leafValue( value( VT("/q1") 82e-12 ) "x" x )
^ This returns a waveform object which shows the final points of each transient for one "x". I can plot this waveform, but I can't access each point in this waveform using "foreach( )" (error: ... can't handle srrWave...). So:
Q1: Is it possible to convert this waveform object to an iterable array/list which I can access as a for/foreach loop? Alternatively how else can I process each point in this waveform.
Q2: Is it possible to access the list of parameter "x" to be iterable using "foreach( )", such that I don't have to edit the script when I change the sweep range of x in the simulator?
Please let me know if I need to clarify the above. Thank you!
  • SC6789
    Found a solution to my Qs.
    Q1:
    After polishing my search keywords I've found Andrew Beckett's function: abWaveToList() archived here:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/25049/how-to-calculate-hysteresis-using-ocean-skill-script
    To access the list of Y-axis points in the waveform an iterate over them I used:
    include("./abWaveToList.il")
    foreach( y_value nthelement( 2 abWaveToList ( leafValue( value( VT("/q1") 82e-12 ) "x" x ) ?transpose t ) )
    ... <perform my processing>
    This greatly sped up the calculations. Thank you, Andrew! If anyone can comment why simply iterating over leafValue( signal param param) is so much slower, I'd appreciate it (access time to reopen the waveform each time?).
    Q2:
    In the same search I stumbled upon:
    famGetSweepValues( VT("/q1") )
    which can be used in foreach statement to iterate over each value of the swept parameter implicitly. Don't know where this function is documented, what kinds of sweeps it works for and how it works for sweeps with multiple parameters.
    Don't know if this post will be removed (for self answering) or moved, but perhaps it can help someone who searches for keywords in the subject line.
    Andrew Beckett over 4 years ago in reply to SC6789
    The reason it would be slower is because (assuming I've understood you're usage) it will have to search along the waveform to find the x-value you're retrieving (possibly interpolating). The waveform is not indexed by the x-values, but by position.
    It is documented. Simply search for it in cdnshelp.
