  3. Control cadence virtuoso through terminal
  • Views 15328
Detailer
Detailer over 4 years ago
Hi all, my goal is to create a UNIX script to automatically launch cadence and do all the simulations needed. I have seen some threads in this forum related to this topic however it seems the virtuoso is not configured in terminal mode. I send a screenshot of what happens when I try to do virtuoso -help. Indeed it launches virtuoso but I can't control it through the terminal. Even launching virtuoso when I am on the work folder does not help. Any ideas on how to fix this ?
Regards and thanks in advance
Alex
    Alex, Presumably that is a wrapper provided by Europractice that is invoking the real Virtuoso underneath. You would need to contact Europractice (helpfully the message even gives you the email address…
  • ebecheto
    ebecheto over 4 years ago +1
    WHouahou ! They called the wrapper `virtuoso' that's a bad idea. To know where they put the wrapper, type : $> which virtuoso You can edit the file, and use only the part where they define the necessary…
    Alex,
    Presumably that is a wrapper provided by Europractice that is invoking the real Virtuoso underneath. You would need to contact Europractice (helpfully the message even gives you the email address!) to find out how to pass arguments through to allow you to run virtuoso in (say) -nograph mode.
  • ebecheto
    WHouahou !
    You can edit the file, and use only the part where they define the necessary environment file (source lot_of_Stuff.sh; source pdk_files.sh)
    If your are stucked with that, you can launch a terminal from within cadence : sh("xterm&")  But that's not what you want i suppose, it is another step to get acces to the simulator (spectre or the one used for your simulation)
    From now, i use in my "starter script" a few lines to start another terminal with the environment variable declared and accessible to the prompt :
    # start a new actif shell with all the environnement variables loaded without sourceing the script
    # but i keep the possibilité to call it like `source cad_pkd.sh'.
    CMD=`cat /proc/$$/cmdline`
    if [[ ${CMD:0:1} = "-" ]] ; then
        echo "_source_ from shell"
    else
        echo "_new shell with environment variable active, can be exited Ctrl-D"
        exec /bin/bash -i
        echo "cmdline = $CMD, so not sourced"
    fi
    # after "exec", grass does not grow ! DO NOT PUT ANYTHING BELOW !
    OK, it is written for bash, but that can be adapted.
    Hope it helps
  • Detailer
    Detailer over 4 years ago in reply to Andrew Beckett
    I contacted Europractice and they pointed out the problem. After running a diagnosis on the packages I had installed on the machine I saw what was missing. It seems the -nograph mode requires Xvfb.
    Once more thanks for all the support given ,
    Regards
    Alex
