  3. Is there a way to generate netlist automatically with recurrence...
  • Subscribers 152
  • Views 6875
Is there a way to generate netlist automatically with recurrence in Virtuoso(from schematic)?
ayayla
ayayla over 4 years ago
We are working in a project with multiple designer and I am maintaining the top level of the design. I am looking if there is a way to generate a netlist recurringly(like every night) in Virtuoso environment such that the design is always netlistable. I know couple ways to generate the netlist manually but I want to do this automatically in terminal with some script. There will be later post-processing log file if it passes or fails(and further actions like sending an email).
In case it is needed, these are spectre and versions
spectre -W => sub-version  20.1.0.231.isr6
ICADVM20.1-64b.NY_201ISR19
yayla
    Presumably you could use this: Generating Verilog Netlist from UNIX command line for Schematic Design and License requirement
    Whether the design is netlistable will depend on whether it has been checked before being saved.
  • drdanmc
    drdanmc over 4 years ago
    I didn't see what type of netlist you are trying to generate (CDL, Verilog, Spectre, etc) and the answer would be different for the different cases.  Here are a few options.  There are likely more.
    spectre:
    The following SKILL code will netlist a design.  You can have a shell script call virtuoso with the "-replay" option to run the SKILL code from a named file.
    ;; specify the netlist directory
    mySimDir = "/tmp/nightly"
    envSetVal("asimenv.startup" "projectDir" 'string mySimDir)
    simulator('spectre)
    design("myLib" "myCell" "myView" "r")
    rc = createNetlist(?recreateAll t)
    unless(rc error("failed to netlist"))
    CDL:
    create a file, si.env, that looks something like this:
    dlSimStopList = '( "auCdl" )
    cdlSimViewList = '( "auCdl" "schematic" "cmos_sch")
    simSimulator = "auCdl"
    simViewName = "schematic"
    simViewList = '( "auCdl" "schematic" "cmos_sch")
    simStopList = '( "auCdl")
    simLibName = "myLib"
    simCellName = "myCell"
    simViewName = "myView"
    and then run
    si -batch -command netlist
    you could wrap this up in a shell script to do some error checking.
    Verilog:
    use the approach Andrew mentioned although I think that uses the OSS netlister or `runams` for using the unified netlister.  Refer to the manual for full details but basic usage is
    runams -lib myLib -cell myCell -view myView -netlist -log mylog.log
    and again, you may want some shell script wrapper to call this and check for success.
