  3. How can I make rodGetObj works on instantiated cell from...
  • Views 11153
How can I make rodGetObj works on instantiated cell from top level?
delgsy
delgsy over 4 years ago
I have a rod object named "polygon0" which is instantiated in top cell.
cvId = geGetEditCellView()  ; this returns the top level cvId
objId = rodGetObj("polygon0" cvId) ; this returns nil
I do not understand the S_hierarchicalName mention in the user guide.
I tried the cell name, but it does not work.
apologize if this turns out to be a basic question.
  • mbracht
    mbracht over 4 years ago +1
    Hi, I'am not really sure what you mean with "instantiated" - that term isn't used for rod objects. You instantiate a master cell and in such create an instance of it, that's what instantiating means…
  • mbracht
    I'am not really sure what you mean with "instantiated" - that term isn't used for rod objects. You instantiate a master cell and in such create an instance of it, that's what instantiating means.
    Or do you place an instance that itself  contains a rod object by the name of "polygon0"? If that is the case you need to use a hierarchical path, for example assume the name of the instance is "I1" then you have to say rodGetObj("I1/polygon0" cv).
    Max
  • delgsy
    delgsy over 4 years ago in reply to mbracht
    "Or do you place an instance that itself  contains a rod object by the name of "polygon0"?"
    yes, this is what I meant.
    And yes, hierarchical path works. Thank you!
    I am wondering now whether there is a better way of doing this if I instantiate this 100 times.
  • mbracht
    mbracht over 4 years ago in reply to delgsy
    well each time you place an instance it has a unique name which you need to use in rodGetObj(..). Assume the instance's OA database object is available in a SKILL variable by the name of inst you then have to go like this:
    (rodGetObj (strcat inst->name "/polygon0") cv)
    regards
    Max
