  3. clear list box value
  • Views 11990
Drake96
Drake96 over 4 years ago
Hola,
I have list box field which contains several items as-
Design1
Design2
Design3
DesignN
Layout1
Layout2
Layout3
LayoutN
how can i do that whn i multi-select Design and layout together from above field, it should prompt error and clear the selected field value(list box)....but when i select any multiple design only or multiple layout it should prompt success.
Also , how to clear pre-selected values from list box field after error prompt?
below is script-
check=hiCreateListBoxField(
?name 'check
?multipleSelect t
?callback "back(hiGetCurrentForm())"
?choices list("design1" "design2" "design3" "layout1" "layout2" "layout3")
procedure(back(form)
; fixed the condition
if(form->check->value == list("design2" && "layout1") then
hiDisplayAppDBox( ?name 'errorbox2 ?dboxBanner "Error" ?dboxText "wrong selected" ?dialogType hicErrorDialog ?buttonLayout 'Close ?buttons 'Cancel)
form->check->value = "" ;;;;;;;;;;;; to clear the selected value from listbox ;;;;;;;;;;;
; added a small form around the field to show the problem
hiDisplayForm(
hiCreateLayoutForm(
'forum21
"Forum21"
hiCreateFormLayout(
'lay
?items list(check)
drake
  • AurelBuche
    AurelBuche over 4 years ago in reply to Drake96 +1
    procedure( back(field form) let( (prev_cb) prev_cb=field->changeCB field->changeCB=(lambda (@rest _args) nil) (if forall( choice field->value (pcreMatchp "design" choice)) || forall( choice field->value…
  • AurelBuche
    Hi, the following sample should give you an example of how you could handle your problem (it only works in SKILL++ though)
    The changeCB argument of hiCreateListBoxField is the right solution for this purpose but you have to be careful not looping it infinitely
    Cheers
    Aurélien
    (inScheme
    (let (form)
      (defun do_nothing (@rest _args)
        "Always return nil, whatever the inputs"
        nil)
      (defun create_form nil
        "Create the form"
        (hiCreateLayoutForm 'custom_form "Custom Form"
          (hiCreateFormLayout 'main_layout ?items (list
              (hiCreateListBoxField ?name 'list_box_field
    ?choices '("Design1" "Design2" "Design3" "Layout1" "Layout2" "Layout3")
                ?multipleSelect t
                ?changeCB
                (lambda (field form)
                  ;; Here we are making sure to deactivate this change callback
                  ;; before updating field value, this avoids generating an
                  ;; infinite loop and crashing Virtuoso
                  (let ((prev_cb field->changeCB))
                    (setf field->changeCB do_nothing)
                    (unwindProtect
                     ;; The following S-expression is run  in a safe environment
                     ;; Even if its body raises errors, `unwindProtect' will make
                     ;; sure to restore the updated changeCB to its previous value
                     (let ((choices (field->value)))
                       ;; Check and update input value
                       (cond
                         ;; No choice, do nothing
                         ((not choices)
                           nil)
                         ;; All choices are 'design', print success
                         ((forall choice choices (pcreMatchp "Design" choice))
                           (info "Success!\n"))
                         ;; All choices are 'layout', also print success
                         ((forall choice choices (pcreMatchp "Layout" choice))
                         ;; If we reach this case, it means both 'design' and 'layout'
                         ;; choices are selected
                         ;; Clear selected values
                         (t
                           (setf field->value nil)
                           (error "Both 'design' and 'layout' choices were selected")
                     (setf field->changeCB prev_cb)
                     ));unwindProtect ;let
                  ));list_box_field
              ));main_layout
          ));def
      (defglobalfun display_gui (@rest _args)
        "Main function, display the GUI"
        (unless form (setq form (create_form)))
        (hiDisplayForm form))
      );closure
  • Drake96
    Drake96 over 4 years ago in reply to AurelBuche
    Thank you Aurel :)
    If possible can you guide in Skill     as Skill++ is very very new to me.
  • AurelBuche
      let( (prev_cb)
        (if forall( choice field->value (pcreMatchp "design" choice)) || forall( choice field->value (pcreMatchp "layout" choice))
           ;; choices are all design or all layout
           info("Success!\n")
           ;; choices are a mix of design and layout
           progn(
             form->check->value = nil ;;;;;;;;;;;; to clear the selected value from listbox ;;;;;;;;;;;
        field->changeCB=prev_cb
    ?name 'check
    ?multipleSelect t
    ?changeCB 'back
  • Drake96
    Thank you Aurel   !!!!!!!!!!! :)
