  3. How to automatically open tabs in SKILL IDE
  • Views 10250
MSchuldt
MSchuldt over 4 years ago
When I'm doing a big PDK update, I'd like to open my techfile, a couple of files with utility code, and maybe 15-30 pcells in the IDE, preferably in a specific order.  It gets really tedious doing this manually, especially when I'm switching between my WFH VM and at-work workstation.  Is there a way to open a list of files using code?  The closest thing I got to a solution uses the hi commands, which works but feels particularly inelegant.
_ilgHiShowFileOpenForm()
(hiFileDialogSetSelection _ilgFileDialog '("/home/path" ( "filename.il")) 'done)
(hiFileDialogDone _ilgFileDialog t)
    You can do this with:
    ilgRunSKILLIDE(?fileList list("~/skill/abInvokeCdfCallbacks.il" "~/skill/abFindUnconnectedInstances.il" "~/skill/CCFcompareXorY.il"))
    The ilgRunSKILLIDE is public, and the ?fileList argument is a list of files to open (in order).
  • MSchuldt
    MSchuldt over 4 years ago in reply to Andrew Beckett
    Ah, much better.
    Thank you, Andrew!
