  3. Copy and Paste Selected Objects While Rotating In Place
  • Views 10392
TryingToSkill
TryingToSkill over 4 years ago
I am trying to copy/paste a group of selected objects. I came across this thread: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/13774/automated-copy-and-rotate but that seems to rotate the objects relative to the entire chip/cell view. I am trying to rotate the objects relative to their own position.
To clarify, right now it seems like if I apply an R90 orientation using dbCopyFig() to an object after I offset it by say -45:0, it doesn't end up 45 microns left of the current selected/copied object and rotated 90 degrees relative to its old orientation, it ends up rotated 90 degrees with respect to the main view's origin and so way off the page.
Anyone know how to copy and paste with an in-place rotation?
Thanks!
    You could either do this in two steps - copy and select (using geSelectFig) the shapes using no transformation, and then use SKILL to flip a selection of instances and shapes in a layout or schematic in place to rotate the selection in-place, or modify that code to accept a list of objects and then copy them first (with no transformation) and set the figs variable near the beginning of the code to the result of that copy. i.e. changing the first few lines to be something like:
    (procedure (CCSflipCopy @key (orient "MY") (relativeTo 'centerBox) (source (geGetSelSet))
      (mode 'move) noSnap
      (win (hiGetCurrentWindow)))
      (let (bbox figs origin transform (cv (geGetEditCellView win)))
        (setq figs (foreach mapcar srcObj source (dbCopyFig srcObj cv)))
    then the rest of the function would be the same as CCSflip. Note I didn't test this...
