  3. About label fonts
  • Subscribers 152
  • Views 12758
About label fonts
StanleyChiu
StanleyChiu over 4 years ago
Here is a label (Metal  pin)
I would like to ask if there is a way to make this label "bold"
but keep the font [stick]
my virtuoso version is ICADVM18.1-64b.500.10
  • sebcliq
    sebcliq over 4 years ago
    Nope. For labels, pretty much everything is like 1990.
    Sebastien
    Andrew Beckett over 4 years ago in reply to sebcliq
    You can switch to using TrueType fonts:
    envSetVal( "layout" "useOverrideFontName" 'boolean t)
    envSetVal( "layout" "overrideFontName" 'string "(stick sansLight)")
    You could pick sansBold as the mapped font if you wish them to be bolder.
    These two options are documented in current versions. A little bit less visible, but it does give you something more modern than the old line fonts.
  • StanleyChiu
    StanleyChiu over 4 years ago in reply to Andrew Beckett
    thanks a lot !
