  3. Convert String in Exponent format "280e-09" to a numerical...
  • Views 2492
Convert String in Exponent format "280e-09" to a numerical format
Pratham VA
Pratham VA over 4 years ago
Working on an Ocean script.
How do I convert exponential numbers to string. Example  "280e-09" to 280e-09
So that I can use it as an argument for awvPlaceXMarker function.
Anchan
    Anchan, Here are several ways: numstr="280e-09" aelNumber(numstr) cdfParseFloatString(numstr) car(linereadstring(numstr)) sscanf(numstr "%g" num) The one I wouldn't use (you might see it used or…
    Anchan,
    numstr="280e-09"
    aelNumber(numstr)
    The one I wouldn't use (you might see it used or suggested elsewhere) is evalstring. The reason being that if the string contains something that is a SKILL function, it will get evaluated and executed as SKILL. Imagine what happens if numstr happened to be "(exit)" ...
  • Pratham VA
    Pratham VA over 4 years ago in reply to Andrew Beckett
    Thankyou Andrew
