  3. Change Label text (Layout view)
  • Views 11101
AlexMr
AlexMr over 4 years ago
In layout view I want rename several label in this way (example):
from A<0:999> to A<1000:1999>
Is possible do this command with a skill script ? I hadn' t found the way using command menu
thanks
    This article will do the job. Note that it says it's for schematics, but it works with layout labels too (I tried it): SKILL to increment or decrement schematic bundled bus bit numbers of a wide wire by a given count, change wire name labels of non-scalar bits
    For example, if you have multiple selected labels, you can do:
    foreach(label geGetSelSet() when(label~>objType=="label" CCSincrLabel(1000 label)))
