  3. "Fixed"+"scalable" stretch form
  • Views 2031
Martinsh
Martinsh over 4 years ago
Dear Sir,
A form has two parts, the left panal and the right panal. There are some fields on the left panal and a report field on the right panal. When stretch the form, the fields on the left panal keep their position and size no change, but the report field scales with stretch. How to realize this form?
Martin
    Martin,
    This example of using nested layouts should show you how to do this - it's a silly made up example that shows the contents of analogLib on the right, and the left fields show the last selected item in the report field. As you resize the form, the report field expands right and downwards, but the left fields stay where they are.
    procedure(CCFcreateFormWithReportField()
      let((report lib lcvList libField cellField viewField libLabel cellLabel
          viewLabel leftGrid)
        ; create some contents for a report field
        lib=ddGetObj("analogLib")
        foreach(cell lib~>cells
          foreach(view cell~>views
            lcvList=cons(list(lib~>name cell~>name view~>name) lcvList)
        lcvList=sort(lcvList
          lambda((a b)
            cond(
              (alphalessp(cadr(a) cadr(b)) t)
              (equal(cadr(a) cadr(b)) && alphalessp(caddr(a) caddr(b)) t)
              (t nil)
        report=hiCreateReportField(
          ?name 'report
          ?headers list(
            list("Library" 100 'left 'string t)
            list("Cell" 100 'left 'string t)
            list("View" 100 'left 'string t)
          ?choices lcvList
          ?selectMode 'single
          ?callback lambda((field _scope selectedItems)
            let((choice (form hiGetCurrentForm()))
              choice=nth(car(selectedItems) field->choices)
              form->lib->value=car(choice)
              form->cell->value=cadr(choice)
              form->view->value=caddr(choice)
        libField=hiCreateStringField(
          ?name 'lib
        cellField=hiCreateStringField(
          ?name 'cell
        viewField=hiCreateStringField(
          ?name 'view
        libLabel=hiCreateLabel(
          ?name 'libLabel
          ?labelText "Library"
          ?justification 'right
        cellLabel=hiCreateLabel(
          ?name 'cellLabel
          ?labelText "Cell"
        viewLabel=hiCreateLabel(
          ?name 'viewLabel
          ?labelText "View"
        ; Create the left panel as a grid layout
        leftGrid=hiCreateGridLayout(
          'leftGrid
          ?items list(
            list(libLabel 'row 0 'col 0)
            list(libField 'row 0 'col 1)
            list(cellLabel 'row 1 'col 0)
            list(cellField 'row 1 'col 1)
            list(viewLabel 'row 2 'col 0)
            list(viewField 'row 2 'col 1)
            list('col_min_width 0 80)
            list('col_min_width 1 100)
            list('col_stretch 0 0)
            list('col_stretch 1 0)
        hiCreateLayoutForm(
          'CCFformWithReportFieldForm
          "Form with Report"
          ; use a horizontal box layout for the left grid (non-stretchy)
          ; and the report (stretchy)
          hiCreateHorizontalBoxLayout(
            'all
            ?items list(
              list(
                ; The vertical box layout is to add a stretch item below
                ; the leftGrid which will expand to fill the vertical space;
                ; This keeps the left fields in the same place vertically
                hiCreateVerticalBoxLayout(
                  'vbox
                  ?items list(
                    leftGrid
                    list('stretch_item 1)
                'stretch 0)
              list(report 'stretch 1)
    procedure(CCFformWithReportField()
      unless(boundp('CCFformWithReportFieldForm)
      hiDisplayForm(inSkill(CCFformWithReportFieldForm))
  • Martinsh
    Martinsh over 4 years ago in reply to Andrew Beckett
    Thanks Andrew! It works.
