  3. Trying to change foundry options constraint group in no...
  • Views 10209
Trying to change foundry options constraint group in no graph mode not working
arpit4667
arpit4667 over 3 years ago
I want to change the foundry constraints (present in options->editor->foundry constraints) from my script. Currently I am using the following commands -
here foundry contains the value of foundry as string. The script gives error as -
  • mbracht
    mbracht over 3 years ago
    It means that leEditorOptionsForm->leAltFoundryCG returns nil. The SKILL command leEditorOptionsForm->leAltFoundryCG->value=foundry is translated into this putprop command:
    (putpropq
        (getq leEditorOptionsForm leAltFoundryCG) foundry value
    with putprop's first argument being (getq leEditorOptionsForm leAltFoundryCG) which - like I said above - is nil.
    Max
    Andrew Beckett over 3 years ago in reply to mbracht
    The correct way to do this is not to mess with the form, but instead to set the appropriate cdsenv variable:
    envSetVal("cdba.layout" "AlternateFoundryCG" 'string "foundry")
  • arpit4667
    arpit4667 over 3 years ago in reply to Andrew Beckett
    thankyou so much! It worked.
