  3. Reading Error messages from CIW
  • Replies 9
  • Views 14514
FranzD
FranzD over 3 years ago
HI,
I recently used CCFcaptureWarnings() to capture the warnings of a called procedure. I found it here: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/38856/reading-warning-messages-from-ciw-using-skill
It works fine and captures all warnings. I now wanted to know if I can capture also the error messages like this?
Franz
    Hi Franz,
    BTW, there's also (since IC6.1.8/ICADVM18.1 ISR1) a built-in function called muffleWarnings which suppresses warnings:
    muffleWarnings(
       expressionsThatProduceWarnings()
    You can then get the warnings using getMuffleWarnings() afterwards.
    For errors, normally this would trigger an error and the program would stop. You can catch these with:
    errset(singleExpression)
    For example:
    errset(1/0)
    This will suppress the error and return anyway - it returns a list of the result - returns nil if there was an error, otherwise a list of whatever the result of the expression would have been. You can get the error displayed by passing:
    errset(1/0 t)
    but the error is still caught.
    The error itself is in errset.errset.
    If you are trying to suppress error messages from caught errors (maybe that's what you're asking?), then you could rewrite CCFcaptureWarnings to CCFcaptureErrors by changing the inner part to:
            let(((report tempPort))
              ,@body
  • FranzD
    FranzD over 3 years ago in reply to Andrew Beckett
    thanks for the reply. Actually I want to write some skill code to verify the callbacks of the CDF parameters. For this case I want to catch warnings and errors but still run my code. So I dont want to suppress the errors and warnings rather then check if there are any and if so save them. For the warnings I did:
    ciwMessage = CCFcaptureWarnings(re = CCSinvokeObjCdfCallbacks(...))
    After that I check the value of re. If it is nil then I store the ciwMessage in a log file. But I saw that this only captures the warnings but there are also some errors which are not stored in ciwMessage, but printed on the ciw. I would like to catch them to. The best solution for me would be to also check if I have errors and/or warnings to log which type of problem occured. Do you have any suggestions for this?
    Franz
    Andrew Beckett over 3 years ago in reply to FranzD
    Hi Franz,
    CCSinvokeObjCdfCallbacks already catches the errors (it uses errset inside) but doesn't suppress the error messages (intentionally). So in that case you could do either:
    ciwErrors = CCFcaptureErrors(muffleWarnings(re = CCSinvokeObjCdfCallbacks(...)))
    ciwWarnings = getMuffleWarnings()
    (note in this case, ciwWarnings ends up being a list). Or you could continue to use CCFcaptureWarnings:
      ciwWarnings = CCFcaptureWarnings(re = CCSinvokeObjCdfCallbacks(...))
    Here's the full CCFcaptureErrors making the changes I suggested earlier:
    defmacro(CCFcaptureErrors (@rest body)
      `let(((tempPort outstring()))
        unwindProtect(
          ; main clause - using dynamic scoping, redirect woport to tempPort
          ; and then invoke the forms passed in as the argument to the
          ; macro
            let(((errport tempPort))
              ,@body
            ; return value is the data written to the string port
            getOutstring(tempPort)
          ; always execute the close even if there was an error in
          ; the code above
          close(tempPort)
  • FranzD
    that helps me a lot! Thank you very much! At last I have a more general question: For the warnings you used woport and for the erros the report. Is there also some general port for the output to the ciw? So that I could use the marco with a different port to get all the information that is printed to the ciw regardless if its warnings, errors or just prints?
    Regards
    Franz
  • AurelBuche
    AurelBuche over 3 years ago in reply to FranzD
    Hi Franz
    Yes, you have poport, woport and errport that respectively prints info, warning and error messages to the CIW
    If you set an outstring port instead of all of them, you can temporarily catch all messages
    Cheers,
    Aurélien
  • FranzD
    FranzD over 3 years ago in reply to AurelBuche
    Hi Aurélien,
    Can you make this a little more clear for me? Lets say I have a function and I want to catch all info, warning and error of it, how would I realize this?
    Thank you!
    Franz
    allOut=CCFcaptureTheLot(...)
    will do this - using this code:
    defmacro(CCFcaptureTheLot (@rest body)
        unwindProtect(
          ; macro
            let(((woport tempPort) (poport tempPort) (errport tempPort))
              ,@body
              ; next two lines are to force final warning to be flushed
              warn("")
              getWarn()
          ; the code above
          close(tempPort)
    If you notice the inner let line is setting woport, poport and errport to tempPort temporarily.
    Franz,
    I should also point out that editing a post after you had replied with just the above doesn't send out another notifier. So it ends up being rather likely that I won't see it (since I don't check the link every time).
    Luckily in this case the further conversation meant I spotted the request.
  • FranzD
    Ok thanks for the note and thanks for the help to both of you!
