  3. Create Report Field
  • Views 9432
Create Report Field
Alei
Alei over 3 years ago
I created a report field to display opened cellview, when I click one item then callback procedure which is "hiRaiseWindow()" will be invoked and then corresponding window will be current window. However this app form is lower level. How can I keep the app form still at the top level after "hiRaiseWindow()" is invoked? thanks in advance.
  • mbracht
    mbracht over 3 years ago
    Well this is what hiRaiseWindow() does - it pops whatever windows you  specify to the top of the window stack. If you just want a window to be the current(!) window use hiSetCurrentWindow() instead. The current window is not necessarily the window on top.
    Andrew Beckett over 3 years ago in reply to mbracht
    You could just also call hiDisplayForm(form) again within the callback to raise the form to the front?
  • Alei
    Alei over 3 years ago in reply to Andrew Beckett
    Thanks, Andrew. your solution works for me.
