  3. Setting up the Bind key .
  • Subscribers 152
  • Views 14965
anola123
anola123 over 3 years ago
I want one key to toggle the visibility (between visible/ invisible) of metal ( say <Key>1 for M1). I used " hiSetBindKey("Layout" "<Key>1" "leSetLayerVisible(\"M1\" t)") " this code to make it visible. Now, how can use the same key to make it invisible ??
  • dmay
    dmay over 3 years ago +1
    Use "not" leIsLayerVisible as the value. hiSetBindKey("Layout" "<Key>1" "leSetLayerVisible(\"M1\" !leIsLayerVisible(\"M1\"))") Derek
  • skillUser
    skillUser over 3 years ago +1
    Hi, You could consider writing a toggle function, or do it directly in the bindkey, e.g. hiSetBindKey("Layout" "<Key>1" "pteSetVisible(\"M1 drawing\" !pteIsVisible(\"M1 drawing\" pteGetCurrentPanel…
    Andrew Beckett over 3 years ago in reply to anola123 +1
    anola123 said: can you brief me about the purpose of this function? Seriously? It's pretty obviously named - leIsLayerVisible determines whether (shock, horror) the given layer is visible or not, and…
  • dmay
    Derek
  • skillUser
    hiSetBindKey("Layout" "<Key>1" "pteSetVisible(\"M1 drawing\" !pteIsVisible(\"M1 drawing\" pteGetCurrentPanel()) pteGetCurrentPanel())")
    Looks like Derek beat me to it, but this solution is slightly different as it uses the pte* prefix functions.  I'd write this as a function that accepts the layer as an argument and then you could use the same function for any layer, something like:
    procedure(CCFToggleLayer(layer "t")
        pteSetVisible(strcat(layer " drawing")
          !pteIsVisible(strcat(layer " drawing") pteGetCurrentPanel())
    Then your bindkey action string would be "CCFToggleLayer(\"M1\")"
    Best regards,
    Lawrence.
  • anola123
    anola123 over 3 years ago in reply to dmay
    Seriously? It's pretty obviously named - leIsLayerVisible determines whether (shock, horror) the given layer is visible or not, and the "!" operator is a not - it inverts the result. So that means that if the layer is visible, leIsLayerVisible(layerName) returns t and !leIsLayerVisible(layerName) would then be nil. So setting the layer visibility to the inverse of the current visibility will toggle the visibility.
    You could also read the documentation.
