  3. How to make shift+enter to create a new line instead of...
  • Views 3751
How to make shift+enter to create a new line instead of executing the command in CIW
JRP29
JRP29 over 3 years ago
Just a basic doubt. Can anyone tell me how to make shift+enter to create a new line instead of executing the command in CIW
    On Options→User Preferences in the CIW, if you have Enter Key Executes Command checked, then Enter executes and Shift-Enter creates a new line. If it's unchecked, then the behaviour is the opposite way around. The default is to be checked (i.e. Enter executes the command) - maybe that's changed in your environment?
  • JRP29
    JRP29 over 3 years ago in reply to Andrew Beckett
    Even after checked the Enter Key Executes Command, I see shift-Enter still executing the command instead of creating new line.
    Andrew Beckett over 3 years ago in reply to JRP29
    My guess is that you have the Syntax Highlighting also unchecked. If you have that unchecked, then pressing Enter or Shift-Enter both execute the command regardless of the setting of Enter Key Executes Command. You can turn these back on (the default is on) in your .cdsinit by doing:
    envSetVal("ui" "ciwSyntaxHighlighting" 'boolean  t)
    envSetVal("ui" "ciwCmdExecuteOnEnter" 'boolean  t)
    (you can check that worked by looking on the Options→User Preferences form to see whether both are checked).
  • JRP29
    Thanks Andrew. Enabling these 2 commands make shift+Enter Key to create new line and Enter key execute command.
