  3. GUI menu to do setShellEnvVar
  • Views 11079
Pedro P
Pedro P over 3 years ago
I need your help to create a GUI that looks like the image bellow.
The basic idea is for the user put the name of the TEST in the open field , then press the button “set TEST env variable” and the skill executes  setShellEnvVar("TEST=whatever is on the field")
can anyone help me with this ?
    Normally I'd expect you to at least have had a stab at it yourself rather than asking others to do it for you - but here's an example I quickly threw together to show how this can be done.
    /* CCFsetEnvVar.ils
    Author     A.D.Beckett
    Language   SKILL
    Date
    Modified
    By
    Example of a form to set a UNIX env variable.
    The code uses SKILL++ semantics and so should keep the .ils suffix
    (this allows us to have local functions within the main function).
    Usage: CCFsetEnvVar("TEST")
    SCCS Info: @(#) CCFsetEnvVar.ils 03/11/23.18:42:19 1.1
    *                   CCFsetEnvVar(envVarName)                   *
    *      Display a form which sets the given UNIX env var.       *
    procedure(CCFsetEnvVar(envVarName)
      *    Local function: setEnvVarCB(_field scope @rest _args)     *
      *   This retrieves the variable name and value from the form   *
      *                     and sets the env var                     *
      procedure(setEnvVarCB(_field scope @rest _args)
        let(
            (varName scope->envVarName)
            (varValue scope->envValue->value)
          when(varName
            setShellEnvVar(varName varValue)
      *            Local function: createSetEnvVarForm()             *
      *   Creates the form - the label, button, and value/defValue   *
      *             of the entry field will be set later             *
      procedure(createSetEnvVarForm()
        hiCreateLayoutForm(
          'CCFsetEnvVarForm
          "Set environment variable"
          hiCreateHorizontalBoxLayout(
            'hbox
            ?items
              list(
                list(
                  hiCreateLabel(
                    ?name 'envLabel
                    ?labelText "envName"
                  'stretch 0
                list(
                  hiCreateStringField(
                    ?name 'envValue
                    ?defValue ""
                  'stretch 1
                list(
                  hiCreateButton(
                    ?name 'setEnvVar
                    ?buttonText "set env var"
                    ?callback setEnvVarCB
                  'stretch 0
          ?buttonLayout 'Close
          ?minSize 350:80
      ; Main body of the function. Create the form if not already
      ; created (the instantiation is necessary because otherwise the
      ; label doesn't get updated the first time around
      unless(boundp('CCFsetEnvVarForm)
        hiInstantiateForm(inSkill(CCFsetEnvVarForm))
      let(
          (form inSkill(CCFsetEnvVarForm))
          (envValue getShellEnvVar(envVarName)||"")
        ; Record the env var name as a property on the form,
        ; and then update the label, button text and the value/default
        ; value of the entry box to be the current value of the env
        ; var
        form->envVarName=envVarName
        form->envLabel->value=envVarName
        hiSetButtonLabel(
          form->setEnvVar
          lsprintf("set %s env variable" envVarName)
        form->envValue->value=envValue
        form->envValue->defValue=envValue
        hiDisplayForm(form)
  • Pedro P
    Pedro P over 3 years ago in reply to Andrew Beckett
    Hi Andrew, thank you so much for the code, I have been struggling with GUIs for a bit as seen by my older post SKILL GUI - Custom IC Design - Cadence Technology Forums - Cadence Community
    Your code, is a great framework to help me developing more complex GUIs, using this as a solid base.
    All works as expected, but there is a small typo on the callback
    line 85: should be                 ?callback "setEnvVarCB()"
  • AurelBuche
    AurelBuche over 3 years ago in reply to Pedro P
    Hi Pedro,
    There is no typo line 85.
    You just registered the file with a different format suffix than the one used by Andrew
    This is SKILL++ and well understood by Virtuoso only with the file format suffix .ils (Andrew called the file CCFsetEnvVar.ils for this reason)
    In SKILL++ functions are objects like strings, numbers etc. and can be set as variable values
    The fix you wrote won't work unless you modify setEnvVarCB arguments as well
    Hope this helps
    Cheers
    Aurélien
    Andrew Beckett over 3 years ago in reply to AurelBuche
    Thanks Aurélien - spot on.
    Pedro P - a little note; your original post didn't mention the problem you'd faced with the callback and you (presumably) edited the post afterwards. There are no notifications sent on edits to existing replies so I didn't see it until Aurélien mentioned it...
  • mbracht
    mbracht over 3 years ago
    the code to do this is little:
    (let (strField btnField topFrame)
       strField = (hiCreateStringField
                      ?name    'strField
                      ?prompt  "TEST")
       btnField = (hiCreateButton
                      ?name    'btnField
                      ?buttonText "set TEST env variable"
                      ?callback (lambda (btn form) (setShellEnvVar "TEST" form->strField->value)))
       topFrame = hiCreateHorizontalBoxLayout( 'topFrame
          ?items (list strField btnField)
          ?horiz_align 'left)
       form = hiCreateLayoutForm(
             'MbrForm "Top Form" topFrame
             ?initialSize 400:75
             ?sizePolicy 'expanding)
       hiInstantiateForm(form)
       hiDisplayForm(form)
    Only I don't understand why you want to wrap a GUI around something so easy like making a call to setShellENvVar().
    Max
