  3. i'm trying to split a shape (polygon) from the middle/any...
  • Views 2041
i'm trying to split a shape (polygon) from the middle/any place based on the co ordinates provided - using lespiltshape command ,it seems that it is not working
RLANDERI1234
RLANDERI1234 over 3 years ago
cvId2=dbOpenCellViewByType("Libname" "all_pch_nch_testcases" "layout" "" "a")
var =getGetSelectedSet()
leSplitShape(car(var) list(0 1) list(0:0 4:4) t t)
bBox of the shape is ((5287 0) (5.387 4.753))
But the shape seems to be not spliting
    Why would it? The split line doesn't even intersect the shape (it must intersect an even number of times, as you'd see if you tried doing this interactively via the Edit->Advanced->Split command).
