  3. Problem with Using Pin Tool
  • Subscribers 153
  • Views 8767
Jinhyung
Jinhyung over 3 years ago
I'm using 'Pin Tool' si usefully, but I found the critical error with this tool.
The case was this.
I had the net named 'EN<1>', so I put the label 'EN<1>' on it.
After that, I clicked 'Pin Tool' -> 'Create' -> 'Create Pin From Label' and made pin succesfully.
However, when I clicked the pin and saw the properites, the 'Pin Name' and the 'Terminal Name' changed 'EN[1]' automatically.(The bracket changed.)
Every pin name with '<>' changed to '[]' after creating pin.
This error seems not critical, but when I use connectivity, it didn't work because of that error.
Is there any solution with this error?
Thanks for your time.
Best regards.
    Which IC sub-version are you using? Help→About in any Virtuoso window will tell you this (please provide the complete version number). I don't see this in IC6.1.8 ISR32 (IC6.1.8-64b.500.32)
  • Jinhyung
    Jinhyung over 3 years ago in reply to Andrew Beckett
    My version is this. "IC6.1.8-64b.500.16"
    In this version, that error happens.
    Best regards.
  • Mikemiles
    Mikemiles over 3 years ago
    [deleted]
  • Jinhyung
    Jinhyung over 3 years ago in reply to Mikemiles
    I figured this out.
    When you use "Auto Label", the option "Create As Label" is not checked. If user doesn't turn on this option, then the error that I wrote here happens.
    However, if user turns off that option, then upper error doesn't happen.
    Best regards.
