  3. How to print all possible combinations from an input list...
  • Views 9187
MorrisDH
MorrisDH over 3 years ago
example input list: p1, p2, etc represent cdf parameter names. The associated list represent the parameter values.
((p1 ("179n" "181n")) (p2 ("45")) (p3 ("70n" "72n")) (p4 ("89n" "91n")) (p5 ("89n" "91n")) (p6 ("3.59u" "3.61u")))
desired output would be all possible combination - there would 32 possible combinations - only first four shown below. The blank line is for clarity but is not required.
p1 "179n"
p2 "45"
p3 "70n"
p4 "89n"
p5 "89n"
p6 "3.59u"
p1 "179n"
p2 "45"
p3 "70n"
p4 "89n"
p5 "89n"
p6 "3.61u"
p1 "179n"
p2 "45"
p3 "70n"
p4 "89n"
p5 "91n"
p6 "3.59u"
p1 "179n"
p2 "45"
p3 "70n"
p4 "89n"
p5 "91n"
p6 "3.61u"
etc
Hope my question is clear.
  • MorrisDH
    I got this to work for a list that has 9 cdf parameters defined. I named the input list "tests"
        foreach(test tests
          cellName = car(test)
          printf("Testing %s\n" cellName)
          test = cdr(test)
          testValues = list()
          foreach(param test
            param = parseString(param " ")
            param = list(stringToSymbol(car(param)) parseString(cadr(param) ":"))
            testValues = append1(testValues param)
          ) ; foreach
          ;println(testValues)
          foreach(i0 cadr(nth(0 testValues))
          foreach(i1 cadr(nth(1 testValues))
          foreach(i2 cadr(nth(2 testValues))
          foreach(i3 cadr(nth(3 testValues))
          foreach(i4 cadr(nth(4 testValues))
          foreach(i5 cadr(nth(5 testValues))
          foreach(i6 cadr(nth(6 testValues))
          foreach(i7 cadr(nth(7 testValues))
          foreach(i8 cadr(nth(8 testValues))
            printf("dbCreateParamInstByMasterName(cvId \"myLib" \"%s\" \"layout\" nil 0:0 \"R0\" 1\nlist(" cellName)
            printf("%L %L\n" car(nth(0 testValues)) i0)
            printf("%L %L\n" car(nth(1 testValues)) i1)
            printf("%L %L\n" car(nth(2 testValues)) i2)
            printf("%L %L\n" car(nth(3 testValues)) i3)
            printf("%L %L\n" car(nth(4 testValues)) i4)
            printf("%L %L\n" car(nth(5 testValues)) i5)
            printf("%L %L\n" car(nth(6 testValues)) i6)
            printf("%L %L\n" car(nth(7 testValues)) i7)
            printf("%L %L)\n)\n" car(nth(8 testValues)) i8)
    It's ugly and it is required to know the number of parameters in advance.
  • AaronSymko
    AaronSymko over 3 years ago in reply to MorrisDH
    Here's a solution that uses recursion:
    procedure( permuteParams(paramList @optional retVal)
      if(length(paramList) == 0 then
         foreach(i retVal
           printf("%s %L\n" car(i) cadr(i))
         ); foreach
         printf("\n")
      else
        let((entry pname plist)
          entry = car(paramList)
          paramList = cdr(paramList)
          pname = car(entry)
          plist = cadr(entry)
          foreach(value plist
            retVal = append1(retVal list(pname value)) ;; push
            permuteParams(paramList retVal)              ;; recurse
            retVal = reverse(cdr(reverse(retVal)))          ;; pop
          ); foreach
        ); let
      ); if
    ); procedure
    Andrew Beckett over 3 years ago in reply to AaronSymko
    I was thinking about this overnight, and indeed a recursive solution is a good way of implementing this. Mine is more efficient (uses less memory and is faster. because it's not using append and reverse throughout), and also returns a list of all the results for convenience:
    procedure(CCFgenerateParamPermutations(assocList @optional cumulative results)
      if(assocList then
        let(((paramName caar(assocList)))
          foreach(value cadar(assocList)
            results=CCFgenerateParamPermutations(
              cdr(assocList)
              cons(list(paramName value) cumulative)
              results
      else
        results=cons(cumulative results)
      results
    Then you can do:
    allPerms=CCFgenerateParamPermutations(data)
    where data is your input assoc list.
  • MorrisDH
    MorrisDH over 3 years ago in reply to Andrew Beckett
    This works very well
