  3. Adding Ocean Measurement Script via SKILL
  • Views 8004
Jetsama
Jetsama over 3 years ago
Hi. I am trying to add an ocean measurement script to a maestro outputs. I found the forum post below but was unable to get axlAddOutputExpr to work for this. I couldn't find any other information about adding these types of outputs. I have looked though all the documentation for the axl and mae API functions but I may have missed one that might work. Has this feature been built into the API? Sorry if I have missed something obvious, thanks in advance!
skill command for adding an ocean measurements file to ade xl output - Custom IC SKILL - Cadence Technology Forums - Cadence Community
    There still does not appear to be an API to procedurally add an OCEAN script output in Explorer/Assembler. The relevant CCR (Cadence Change Request) is 1279115 - you should contact customer support if this is what you are looking for so that another duplicate can be filed (there are a few duplicates already; the more there are the more likely it is to be implemented).
