  3. Getting multiple Dock window attached to layout window when...
  • Views 7002
Getting multiple Dock window attached to layout window when used with deRegUserTriggers
SHANMUG
SHANMUG over 3 years ago
After creating dockable window containing a form, how to locate and delete in order to recreate the dockable window and form - Custom IC SKILL - Cadence Technology Forums - Cadence Community
I am using a dock window script mentioned in above link and trying to attach it to the deRegUserTriggers. so that everytime i open the layout window the dock window will be attached to it.
deRegUserTriggers("maskLayout" nil nil 'my_app_map_dwin)
It works fine when i open the layout window. But when i change it to edit/read mode again it triggers and add one more dock window to the layout window.
How to avoid getting multiple dock windows.
Shanmug.
  • SHANMUG
    SHANMUG over 3 years ago in reply to AurelBuche +1
    Thanks Aurélien. Second option is working as i expected.
  • AurelBuche
    AurelBuche over 3 years ago
    Are you using the first solution or the one with a table referencing one dockable window per session one?
    With the first solution, your issue is expected but I'd be surprised if it happens with the second one
    Cheers
    Aurélien
  • SHANMUG
