  3. How to flatten a gds/oas file?
  • Views 6523
SSR
SSR over 2 years ago
Is it possible to flatten a gds/oas file in command-line before streaming in to the Virtuoso env?
If yes, whats the method? If not, is this something that can be achieved using a SKILL code?
Ram
  • SSR
    Is it possible to flatten a gds/oas file in commandline before streaming in to the Virtuoso env?
    Ram
  • ebecheto
    ebecheto over 2 years ago
    Hi Ram,
    Here is an example to flatten an instance in SKill :
    pavement=dbOpenCellViewByType( "your_lib" "pavement" "layout" "maskLayout" "r")  cv= geGetWindowCellView()
    inst=(dbCreateInst cv pavement nil 0:0 "R0");<== insert pavement in cellView
    dbFlattenInst(inst 1 nil t)
    Although, it will flatten only one level of depth in the hierarchy. I think there is in one menu a Flatten-all hierarchy button.
    Furthermore, if you want to simplify the gds and reduce data, you can possibly merge shapes and polygons :
    geSelectAllFig() leHiMerge() leHiConvertShapeToPolygon()
    Hope it helps,
    Regards
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Ram,
    There is a support article that should be covering what you ask for :
    XStream In: Is there a way to flatten top cell layout during File Import Stream?
    This one might be useful in case you want to do the opposite :
    How to generate flat GDS data from layout using XStream Out or strmout
    Cheers,
    Aurélien
  • SSR
    SSR over 2 years ago in reply to AurelBuche
    I need to flatten the gds/oas db before I could stream in so that the stream-in process don’t mess up the library creating many different cells/views for the design hierarchy. I've seen the article, but it seems like they are flattening the db after streaming in, which fails what i'm trying to achieve here.
    Andrew Beckett over 2 years ago in reply to SSR
    You could either:
    1. Stream in (with the flatten code) into a temporary library and then copy the top cell out afterwards, and then delete the temporary library
    2. Modify the code in the first article that Aurélien mention to traverse the hierarchy, collect all the cellViews used, and then delete them after flattening (have to be careful to only delete those in the same library just in case you have references from other libraries).
    I think the first approach is safer. After all, how often are you likely to need to do this - it doesn't sound too onerous to me.
  • RobMan
    RobMan over 2 years ago
    Apologies for the delay... I had a ascertained this was probably possible with the Design Review QUAKE tool but it's a flow I have not worked with much. After a little reference to docs etc. I found this works:
    Create a file (e.g. quakeFlat.py) containing...
      #!/bin/python3
      gdsPath = './aCellLvlTop.gds'
      cell = 'aCellLvlTop'
      gdsOut = './aCellLvlTopFlat.gds'
      dbId = k2_quake.data_read_file(gdsPath, cell)
      cell_extents = k2_quake.data_get_db_cell_extent(dbId, cell)
      k2_quake.data_db_extract(dbId, gdsOut, cell, cell_extents)
    Obviously substitute filenames accordingly. Then run as follows..
      k2_quake_python quakeFlat.py
    N.B. This will require access and licences for PVS/Pegasus Design Review.
