  3. Generate Layout hierarchy, ignoring existing layouts of...
  • Replies 10
  • Views 11016
Generate Layout hierarchy, ignoring existing layouts of subcells.
vtboy51
vtboy51 over 2 years ago
I have written a SKILL script that uses the function lxGenFromSource to generate the layout view. The purpose of the code is to do an area calculation of each device, and I would like to ignore any existing layout views that exists and always generate "new" layouts (which is always done in a scratch library). Is there an environment variable I can set?
  • RobMan
    RobMan over 2 years ago
    'lxGenFromSource' accepts a lib/cell/view arguments so you can specify it that way....
    lxGenFromSource(
    d_schCellViewID
    [ ?layLibName t_layLibName ]
    [ ?layCellName t_layCellName ]
    [ ?layViewName t_layViewName ]
    [ ?configLib t_configLib ]
    [ ?configCell t_configCell ...........
  • vtboy51
    vtboy51 over 2 years ago in reply to RobMan
    So I do use the lib/cell/view fields to define where to generate the layout cells in, but if a layout cell exists in my schematic library (which is not where I've specified the layout to be generated) it will still pull it from the schematic library and instantiate it.
  • RobMan
    RobMan over 2 years ago in reply to vtboy51
    That would be my expectation.
  • vtboy51
    I would think there is somewhere I can add an "ignore" library list to my settings, such that it won't look in that list of libs for layout cells. My temporary fix is to copy the schematics hierarchically into a new library (minux layouts) and then run, but that obviously is a pain each time.
  • RobMan
    Apologies, I think I might have misunderstood the previous statement. Are you suggesting you specify lib/cell/view and it is ignored?
    e.g. You have schematic design 'myLib aCell schematic'. You call
    lxGenFromSource(
    dbOpenCellViewByType("myLib" "aCell" "schematic")
    ?layLibName "myLayoutLib"
    ?layCellName "aLayoutCell"
    ?layViewName "layout"
    But the cell 'myLib aCell layout' is created?
  • vtboy51
    Correct. I set "cv" equal to my current schematic library (which has existing layout views), and then pass that into the lxGenFromSource function. In that function I specify a layoutLibName, layoutCellName, and layoutViewName which are different than the schematic library.
    cv = dbOpenCellViewByType(schLibName schCellName "schematic" "schematic" "w")
    ;CADENCE FUNCTION FOR DOING GEN FROM SOURCE
    lxGenFromSource(cv
    ?layLibName layoutLibName ;LAYOUT LIB NAME
    ?layCellName layoutCellName ;LAYOUT CELL NAME
    ?layViewName layoutViewName ;LAYOUT VIEW NAME
    ?initDoStacking "t" ;AUTO ABUT MOS INTO CHAIN
    ?initCreateInstances t ;GEN ALL INSTANCES IN SCH W/O IGNORE PROP
    ?lxGenerateInBoundary t ;GEN INSIDE BOUNDARY SHAPE
    ;?lxPositionMinSep deviceSep
    ?initAreaSource1 "Utilization"
    ?initAreaSource1Val 100.0
    ?initAreaSource2 "AspectRatio"
    ?initAreaSource2Val 1.0
    ;?extractAfterGenerateAll nil
    ;?extractSchematic nil
    );end lxGenFromSource
  • RobMan
    I assume you are quoting (string) the layoutLibName, layoutCellName & layoutViewName).
    This works. Creating a new layout view 'layoutLibName layoutCellName layoutViewName'
    If it's not working for you I suggest you connect customer support. There's probably some subtle mistake somewhere.
  • RobMan
    Are you referring to layout views in the design hierarchy and not just the top cell layout?
  • vtboy51
    Correct on the quoting (string) question. And yes, I'm referring to the layout views down through the design hierarchy. The top cell is created new in the specified library, it is all the subcells that I want to force to be new instead of instantiating from the original schematic library.
  • RobMan
    OK, sorry. That wasn't clear. Generate From Source only creates the top level layout cellview.
    You can edit the physConfig to 'force descend' on cells/instances. But this will flatten the hierarchy one level.
    A better solution for you is probably to us 'Design Planner' within Virtuoso. This is an EXL feature. Please see...
      ICADVM20.1 Virtuoso Design Planning and Analysis (cadence.com)
    This enables you to create virtual hierarchy for missing or existing instances. Optmising placement from the top level. switching to/from cells or virtual hierachy as required.
