  3. Skill code to Get all the lib and views used in cell from...
  • Views 8823
Skill code to Get all the lib and views used in cell from top to bottom hierarchy
ManjunathYalameli
ManjunathYalameli over 2 years ago
Hi All,
I am looking for a code to list all the Lib and views are used in cell from top to bottom hierarchy, Note: without listing duplicates.
And if view is other then layout it should display lib cell name and view name.
Thanks in advance
Regards
Manju
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Manju,
    The following snippet might be a good start for you
    (inScheme
    (let ()
      (defun get_view_type (lib cell view "ttt")
        "Return LIB/CELL/VIEW view type, return nil if LIB/CELL/VIEW does not exist"
        ;;  From Cadence Support: "How can I get view type of cellView using SKILL?"
        ;; support.cadence.com/.../ArticleAttachmentPortal
        (and (eq 'ddViewType (type (ddGetObj lib cell view)))
             (ddMapGetFileViewType (ddGetObj lib cell view "*"))
             ));and ;def
      (defun get_sch_view (lib cell "tt")
        "Return first valid schematic view name out of LIB/CELL"
        (when (eq 'ddCellType (type (ddGetObj lib cell)))
          (car (exists view (parseString (envGetVal "schematic" "viewNameList" 'string))
                 (equal "schematic" (get_view_type lib cell view))
          ));when ;def
      (defun apply_to_hierarchy (fun cv)
        "Apply FUN recursively to all cellviews from CV hierarchy"
        (funcall fun cv)
        (foreach sub_cv cv->instanceMasters
          (apply_to_hierarchy fun sub_cv)
          ;; When view is a symbol one, apply also fun to associated schematic one
          (when (equal "schematicSymbol" sub_cv->cellViewType)
            (letseq ((sch_view (get_sch_view sub_cv->libName sub_cv->cellName))
                     (sch_cv   (and sch_view (dbOpenCellViewByType sub_cv->libName sub_cv->cellName sch_view)))
              (when sch_cv (unwindProtect (apply_to_hierarchy fun sch_cv) (dbClose sch_cv)))
              ));letseq ;when
          ));foreach ;def
      (defglobalfun cst_flatten_hierarchy (cv "d")
        "Return flat hierarchy from CV"
        ;; Create and fill table containing all lib/cell/view tuples
        (let ((table (makeTable 'lcv nil)))
          (apply_to_hierarchy
            (lambda (cv) (setf table[(list cv->libName cv->cellName cv->viewName)] t))
            cv)
          ;; Return all lib/cell/view tuples
          table[?]))
      ));Scheme closure
    It should work on both schematic and layout views (not on config views though)
    Cheers
    Aurélien
  • RK56
    RK56 over 2 years ago in reply to AurelBuche
    Manjunath,
    Another method would be to get the hierarchy tree from layout and process the output with shell (sort and uniq). This approach also works in terminal with 'fasttree' command
    -Ramakrishnan
  • ManjunathYalameli
    ManjunathYalameli over 2 years ago in reply to AurelBuche
    Hi Aurel,
    Thanks for the script, it's working very well. And results are same as fastTree.
    regards
    Manjunath
  • ManjunathYalameli
    ManjunathYalameli over 2 years ago in reply to RK56
    Hi RamaKrishanan,
    Thanks for the reply, let me try that.
    regards
    Manjunath
