  3. To adjust the length of automatically generated wires after...
  • Views 8014
To adjust the length of automatically generated wires after pressing space in schematic
Eleanor Grace
Eleanor Grace over 2 years ago
When I select a symbol in Virtuoso Schematic and press the space in the keyboard, Cadence adds the wires around the symbol.
How to increase the default length of generated lines and the font size of labels in a schematic view.
thanks
    The length of the stub is controlled by this cdsenv var:
    schematic stubLength int 2
    (the number is the number of grid points of the minor grid).
    The label sizes are controlled by:
    schematic createLabelFontHeight float 0.0625
  • Eleanor Grace
    Eleanor Grace over 2 years ago in reply to Andrew Beckett
    Thank you for your response. The method you mentioned is effective. However, when I increase the length of the wire, the automatically generated label remains close to one side of the pin. Is there a way to center it along the middle of the wire?
    Thanks.
    Andrew Beckett over 2 years ago in reply to Eleanor Grace
    I don't believe there's any control for that, as far as I know.
