  3. Assign a value to a symbol created by concat
  • Views 8003
Martinsh
Martinsh over 2 years ago
I want to assgian a value to a symbol created by concat as following skill code, but error is reported. How should I do?
for(i 1 9
    concat('a i) = i*2
Thanks, Martin
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Martin
    The function you are looking for is
    set
    Andrew Beckett over 2 years ago in reply to AurelBuche
    In addition, you should consider whether this is the right approach. Perhaps you should be using an array or a hash table instead? Symbols are not garbage collected, so unless there's a very good reason, creating new symbols as a pseudo-array as you've described is not the best idea...
  • Martinsh
    Martinsh over 2 years ago in reply to AurelBuche
    AurelBuche,
    It works. Thanks!
    Martin
  • Martinsh
    AurelBuche,
    Another question, how to get the value assigned to the symbol by set(concat('a 1) 1)? get() function doesn't work.
    for(i 1 9
        println( get( concat('a i)) )
    Thanks!
    Martin
  • mbracht
    mbracht over 2 years ago in reply to Martinsh
    for(i 1 9
        (println (symeval concat('i k)))
  • AurelBuche
    AurelBuche over 2 years ago in reply to Martinsh
    Hi Martin,
    You should really consider Andrew's answer above
    Constructing symbols is usually a bad habit.
    It is hard to understand when you share your code and tricky to debug as you have to deduce where the symbols were built
    If you are trying to access the stored values using `get ` probably means that using tables or DPLs is more suitable
    Cheers
    Aurélien
