  3. Create tiles using SKILL
  • Views 7120
ArbLouis
ArbLouis over 2 years ago
I'd like to create tiles within a specific area (0:0 L:W) in Cadence Virtuoso Layout.
Tiles can be simple paths which I can draw using a nested function. Is there a way to avoid writing two cycles to perform this function? I've seen the Mosaic functions but I have an issue in using them. For instance:
dbCreateSimpleMosaic(cv masterTile "myMos" 0:0 "R0" 5 7 3 2)
How do I get the values of
d_cellView
Database ID of a cellview.
and
d_masterCellView
Database ID of a master cellview.
I'm using this code within a PCELL which is defined at the beginning of the function as:
pcDefinePCell(
list(ddGetObj("MY_PCELLS") ; target library
"Stub_vers1" ; target cell
"layout") ; target view
---> Solution found here:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/13999/dbcreateparamsimplemosaicbymastername
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Louis,
    I am not sure if using mosaic and pcells is the best solution
    You should have look at rodFillBBoxWithRects which might do what you are looking for
    Cheers
    Aurélien
  • ArbLouis
    ArbLouis over 2 years ago in reply to AurelBuche
    Thanks a lot Aurèlien
