  3. Create vias in a rectangular area
  • Replies 8
  • Views 11998
ArbLouis
ArbLouis over 2 years ago
Hi! I'm using IC6.18 and I'm trying to write a SKILL function to create a via array in a specific area.
I'm using this code:
constraintGroupId=cstFindConstraintGroupIn(tfId "default")
viaOpts=viaGetViaOptions(constraintGroupId)
viaOpts~>createInRoute = nil
ptArray=list('(0 27) '(20 27) '(20 37) '(0 37))
x1 = 0
y1=MicrostripGroundWidth/2+NGapTiles*TileL
x2 = MicrostripL
y2 = MicrostripGroundWidth/2 + NGapTiles*TileL + MicrostripSideViaWidth
;ptArray=list('(x1 y1) '(x1 y2) '(x2 y2) '(x2 y1))
viaGenerateViasInArea(pcCellView ptArray viaOpts ?topAndBottomLayers list("M2" "M3"))
It creates the vias if I define the ptArray as an array of fixed points. However, even in this case, the layout shows a white cross flashing which disappears as I comment the viaGenerateViasInArea line.
Moreover, when I try to relate the area to some variables, I get error (see the commented ptArray definition). The error I get is this one:
*Error* viaGenerateViasInArea: Invalid point list - ((x1 y1) (x1 y2) (x2 y2) (x2 y1)).
I hope someone could help. Is there an easier way to generate vias in a specific area? Thank you.
  • AurelBuche
    AurelBuche over 2 years ago
    Hi Louis,
    For the white flashing cross, there is probably a warning associated to the generated via (maybe a short), you might be able to find the root cause using in the Layout Toolbar "Verify" -> "Markers" -> "Explain" or "Find..."
    For the ptArray issue, it's just that you are passing the variables names instead of their value
    (As said in the error message, it tries to deduce points from the symbols x1, y1, etc. which are not numbers)
    You should use list or range to provide them
    ptArray=list( (list x1 y1) (list x1 y2) (list x2 y2) (list x2 y1))
    ptArray=list( x1:y1 x1:y2 x2:y2 x2:y1 )
    (Both solutions are valid as long as x1, y1, ... are numbers)
    Another solution is to use backquote which
    ptArray=`( (,x1 ,y1) (,x1 ,y2) (,x2 ,y2) (,x2 ,y1) )
    list evaluates all arguments and you can quote some if you want
    while backquote quotes all arguments and you can evaluate the ones you want using comma
    Also, please note that you don't need to use list if all the elements are simple atoms (numbers, strings, ...)
    can be replaced by
    ptArray='((0 27) (20 27) (20 37) (0 37))
    Hope this helps
    Aurélien
  • ArbLouis
    ArbLouis over 2 years ago in reply to AurelBuche
    Dear Aurèlien,
     thanks for your suggestions which are working fine. Thanks a lot! The only issue is the persisting flashing white cross. I'm trying to attach here below the file with the report. The vias are basically done between two metal layers M2 and M3. A very simple condition. If I remove the via function, the white cross disappears. I hope you can help.
    I see also this error in the CIW window: Invalid bounding-box for a rectangle
    I see the cross when I instantiate the cell.
    Fullscreen Marker.txt Download
    reason:   (VIA-1010): Running the auto via command in area (0, 27) (0, 37) (20, 37) (20, 27).
    reason:   ********************************************************************************
    reason:   *                             Auto Via Statistics                              *
    reason:   * Area : (0, 27) (0, 37) (20, 37) (20, 27)                                     *
    reason:   * Run Time = 0.10 sec [cpu: 0.09 sec]                                          *
    reason:   * Total number of vias created: 1                                              *
    reason:   #
    reason:   # Summary
    reason:   ==================================================================================================================
    reason:   | Stack |  Metal Overlaps   |      Via      |    Initial Overlaps     |        Final Results        |  Percent   |
    reason:   | Depth |  Bottom - Top     |               |   Total   | Unconnected | Newly Connected | Connected |            |
    reason:   ------------------------------------------------------------------------------------------------------------------
    reason:   |   1   |      M2 - M3      |     VIA2      |         1 |           1 |               1 |         1 |   0 -> 100 |
    reason:   |                 Totals                    |         1 |           1 |               1 |         1 |   0 -> 100 |
  • ArbLouis
    ArbLouis over 2 years ago in reply to ArbLouis
    --> Partial solution
    After searching basically all the forum entries for the GenerateViainArea Function, I've found this one: community.cadence.com/.../mute-viagenerateviasinarea-echo-off-verbose-printf
    which I've tried  and it worked fine to remove the white flashing cross after the procedure I'm using to create the via is loaded in SKILL IDE:
    myViaOptions->automatic->printStatisticsReport=nil
    I was happy but, as I try to run EMX, I get the error: "strmount failed streaming out cell".
    I've run Lint of the code and I see this error:
    Variables used as both global and local:
    pcCellView
    From what I could see, pcCellView is the current PCELL being created through the .il SKILL file.
    pcCellView is an internal variable automatically created by pcDefinePCell. pcCellView contains the dbID (database identification) of the cell you are creating. Within the body of your Pcell code, use the pcCellView variable as the cellview identifier for which you create objects.
    Interestingly, I see the white flashing cross when I open Cadence and the cell. As I load the .il code which is generating it, the white flashing cross disappears.
    Any help would be extremely appreciated.
  • ArbLouis
    In the hope to get a feedback, I'm reporting here the code I'm using:
    pcDefinePCell(
    list(ddGetObj("MY_PCELLS") ; target library
    "Via_vers2" ; target cell
    "layout") ; target view
    (Strip float(20.1))
    let(
    ; get the layer info from the techfile
    tfId = techGetTechFile(pcCellView)
    /* Microstrip ground down*/
    fig=dbCreateRect(
    pcCellView ; cell reference
    list("M2" "drawing") ; layer
    list(
    0:0
    Strip:Strip)
    ); fig
    viaOpts~>automatic~>printStatisticsReport=nil
    x1=0
    y1=0
    x2 =Strip
    y2 =Strip
    fig=viaGenerateViasInArea(pcCellView ptArray viaOpts ?topAndBottomLayers list("M2" "M9V"))
    ) ; let
    ); fun
    I get the correct layout:
    But I also get the "strmount failed..." error when I try to run EMX simulations.
    I would be very grateful if someone can help.
  • ArbLouis
    I'm still struggling with this problem.
    I've noticed that when opening a layout including the vias created with the previously described pcell (Via_vers2), a white flashing cross appears. The CWS reports:
    Pcell evaluation for MY_PCELLS/Via_vers2/layout generated information. See layer/purpose "marker/error" shape with property "drcWhy" for description. You can get more details from file /tmp/_pcEvalac3585.
    The file pcEvalac3585 contains:
    Loading via.cxt
    The marker error layer shows a rectangle covering the via areas. I would be really grateful if someone can help.
  • ArbLouis
    Apparently, the issue is caused by the following lines of code:
    cons=cstGetDefaultConstraintGroupName(pcCellView "Via"); "tech:virtuosoDefaultSetup(cmos065_tech)"
    constraintGroupId=cstFindConstraintGroupIn(tfId "virtuosoDefaultSetup")
    As I try to extract via options, the streamout error appears. If I try to run this sequence step by step in the CIW, I get this error:
    *** Error in routine eval:
    Message: *Error* eval: unbound variable - viaOpt
    Entering new debug toplevel due to error:
    By inspecting viaOpt I get:
    viaOpts~>??
    (createInRoute t createAsROD nil rodName
    "" automatic via:0x3ccb90f0 constraintGroupSetup via:0x3ccb9030
  • AurelBuche
    AurelBuche over 2 years ago in reply to ArbLouis
    It seems that you have a typo between viaOpts and viaOpt...
    Cheers,
    Aurélien
    Also, from what I sent you in direct messages, viaGenerateViasAtPoint should not be used in pCell code but it also includes viaGenerateViaOptions, etc.
    Here's the reference (For the clarity of this thread)
    From this article  AUTOVIA: SKILL API for generating vias in layout which does not require Create Via form interaction. viaGenerateViasAtPoint function needs 12 GXL tokens or EAD or EXL license and is not supported in pcell code - gives pcellEvalFailed during strmout
    You can see
    In IC6.1.7.500.7 and ICADV12.2.500.7 a new set of via generation SKILL API's has been released which helps with autovia creation.
    NOTE: These functions are not supported in a pcell code i.e. within pcDefinePCell. Using them in pcell may result in error pcell evaluation failure during Stream Out or Xstream Out or GDS creation:
    Andrew Beckett over 2 years ago in reply to AurelBuche
    In addition, you should read this chapter in the documentation: Safety Rules for Creating SKILL Pcells
